Re: [Techtoolslist] Fluke 9100A - Cannot boot from system disks
Hi, Can someone direct me to a working unserialized version of 6.1 ? So far, I tried these three image sets and used Samdisk 3.8.11 to copy them on a floppy. They all gave me the same error during installation. ftp://ttl.arcadetech.org/TTL/Test_Equipment/Fluke/9100%20Series/System_DiscsRV6.1_VerifiedOK/ https://github.com/ieure/fluke-9100-disk-archive/tree/master/9100-SYSTEM-V6.... https://github.com/ieure/fluke-9100-disk-archive/tree/master/9100-SYSTEM-V6.... Thanks ! Marc ________________________________ De : John Robertson <jrr@flippers.com> Envoyé : 16 mars 2020 12:02 À : Marc Desfossés <mdesfoss@hotmail.com> Objet : Re: [Techtoolslist] Fluke 9100A - Cannot boot from system disks On 2020/03/16 8:59 a.m., Marc Desfossés wrote:
Thank Steve. I did that yesterday and the machine works fine. Just not sure what is going on with the disk/image.
I will try with a Gotek to see if the drive is the problem.
Marc
Most disc images are serialized - they are specific to the machine and can't work on others! I should probably pull them, but someone might be interested in defeating that bit. The 6_1 that is up has had the serial number test disabled (as I recall)... John :-#)#
________________________________ De : Techtoolslist <techtoolslist-bounces@flippers.com> de la part de Steve Larkins <steve@ukaudiovisual.co.uk> Envoyé : 16 mars 2020 11:50 À : Technical Tools Mail List <techtoolslist@flippers.com> Objet : Re: [Techtoolslist] Fluke 9100A - Cannot boot from system disks
Hi Marc A member on here uploaded a V6_1 image to the FTP which is complete and ready to go. it is located here: ftp://ttl.arcadetech.org/TTL/Test_Equipment/Fluke/9100%20Series/v6_1-Disk_Image.rar
Unzip it and use winimage to write it to your SD card..
On Sun, 15 Mar 2020 at 17:10, Marc Desfossés <mdesfoss@hotmail.com> wrote:
Hi,
I am trying to setup a 9100A unit. The initial hard disk was defective. I had a "missing hard drive" error message.
I've upgrade the roms to the V5 version and setup a SCSI2SD drive. I was able to format the disk with service disk 1.4
Whenever I try to boot from the system disks (tried original disks 4.1, images from 6.0 and 6.1), I get an error:
Error 243 loading /dd/rom/appl
I can skip it but then then I get more errors:
root: appl missing root: Can't start application Path Name not found
And the unit freezes at Initializing system.
Error 243 is a CRC error based on the documentation. The floppy drive seems fine since I can load service disk 1.4. I thought that I did not restore the images properly but since I also get the error with original 4.1 disks, I am not sure what I can try next.
Did anyone have had a similar problem ?
Thanks
Marc
_______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
_______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
-- John's Jukes Ltd. MOVED to #7 - 3979 Marine Way, Burnaby, BC, Canada V5J 5E3 Call (604)872-5757 (Pinballs, Jukes, VideoGames) flippers.com "Old pinballers never die, they just flip out" _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Marc Desfossés <mdesfoss@hotmail.com> writes:
Hi,
The second set you linked is what you want:
I created those dumps and have installed several machines, both 9100A and 9100FT, with them. They are exact, low-level copies of virgin factory media. How are you writing the images to the disks? Did you read the section of the README that covers use of high-density drives and media? https://github.com/ieure/fluke-9100-disk-archive/blob/82106be9fd9144390507e4... -- Ian _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Hi Ian, I am using samdisk on a Windows 2000 PC to write images on disks. The floppy drive is HD. I write them using this commandline. It worked for disks such as the service disk 1.4. samdisk copy STREAM A: The disks I am using are double density disks that were brand new. They actually came with the Fluke and have a Fluke sticker on them. I did read the README where you explain some problems writing with HD drive and media. I also tried formatting the disks with the 9100A first as suggested in the README with no luck. Are you burning your images with samdisk or dtc ? Thanks Marc ________________________________ De : Techtoolslist <techtoolslist-bounces@flippers.com> de la part de Ian Eure <ian@retrospec.tv> Envoyé : 16 mars 2020 22:03 À : Technical Tools Mail List <techtoolslist@flippers.com> Objet : Re: [Techtoolslist] Fluke 9100A - Cannot boot from system disks Marc Desfossés <mdesfoss@hotmail.com> writes:
Hi,
I created those dumps and have installed several machines, both 9100A and 9100FT, with them. They are exact, low-level copies of virgin factory media. How are you writing the images to the disks? Did you read the section of the README that covers use of high-density drives and media? https://github.com/ieure/fluke-9100-disk-archive/blob/82106be9fd9144390507e4... -- Ian _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
I also have a box of virgin/blank Fluke floppies and I've had no issues writing them (using dtc) and reading them on the Fluke. I've however had issues trying to use Fluke branded floppies that have been previously used, all kinds of errors when reading on the Fluke. If I were you (since you have the temporary workaround of using the ftp HDD image) I'd just install a Gotek and be done with floppies. The Gotek is far more useful and more importantly, far more reliable. Just remember that you need to set the floppy type to Sony in the firmware, if it's set to Canon you're going to have to start messing with signalling lines to get the Gotek to work [yes this will impact the disc change detect test referenced in the manual but I've found no case where this is actually relied upon; rather there is always "press any key" manual detection]. Since you have a working service disk floppy you should be able to do this, or as you found you can just write a service disk floppy to an SDcard and boot it using SCSI2SD. Tony _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
I should add, that if you go this route you'll need to convert the git repo to a format suitable for the Gotek. I batch converted the entire repo to HFE a while ago, if anyone wants this, drop me a line. _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Hi, I tried the Gotek with hxc firmware and and hfe image files (Thanks Tony !!) I still get an error on system disk 2. It's a different error this time. I tried both 6.1 and 6.0 images. Error 205: /dd/rom/level1 Looking at the OS-9 doc, here is what it means 205: ILLEGAL MODULE HEADER - The specified module cannot be loaded because its module sync code is incorrect. I was able to skip it and this time I was able to boot the system from the disk. Could it be the floppy controller logic that is problematic ? Marc ________________________________ De : Techtoolslist <techtoolslist-bounces@flippers.com> de la part de Tony Jones <tony@tonyjones.com> Envoyé : 17 mars 2020 13:13 À : Technical Tools Mail List <techtoolslist@flippers.com> Objet : Re: [Techtoolslist] Fluke 9100A - Cannot boot from system disks On Tue, Mar 17, 2020 at 10:05 AM Tony Jones <tony@tonyjones.com> wrote:
I should add, that if you go this route you'll need to convert the git repo to a format suitable for the Gotek. I batch converted the entire repo to HFE a while ago, if anyone wants this, drop me a line. _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Can you format the scsi2sd card (from recovery) and then once you reach the above step after booting from Gotek can you copy the files from the system and master "floppies" onto the sdcard? Then when booting from sdcard do you get the same error? I sold three As earlier this year, and reinitialized their HDDs using a Gotek and I don't recall seeing the same. If you want to post the Fluke rom firmware version you have, gotek firmware variant/version and md5sum of each hfe image and I'll see if I can reproduce but It may take me a while as all my remaining As have dead screens and I'll have to take a screen off an FT. Tony _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Hi,
Once the system is up (after ignoring the error 205 on disk 2), I can copy disk 1 but I am unable to copy disk 2 or 3. It says INVALID FILE after about 45 seconds. I cannot ignore this error so the copy ends there. I tried the TEAC drive and it's the same as Sony. To be sure it was not related to the HxC firmware, I installed FlashFloppy 3.13 and set the drive back to Sony. I get the same ERROR 205. I see there is a Test Floppy Disk option in service disk 1.4 but it's not implemented. It's not there at all on Service disk 6. Is there a known way to perform a Floppy Test ? The only thing I have not updated yet is the RAM (Still at 2Mb). I do not think that 2Mb is the issue since I can load from the hard disk. Thanks Marc ________________________________ De : Techtoolslist <techtoolslist-bounces@flippers.com> de la part de Tony Jones <tony@tonyjones.com> Envoyé : 17 mars 2020 20:34 À : Technical Tools Mail List <techtoolslist@flippers.com> Objet : Re: [Techtoolslist] Fluke 9100A - Cannot boot from system disks On Tue, Mar 17, 2020, 4:53 PM Marc Desfossés <mdesfoss@hotmail.com> wrote:
Can you format the scsi2sd card (from recovery) and then once you reach the above step after booting from Gotek can you copy the files from the system and master "floppies" onto the sdcard? Then when booting from sdcard do you get the same error? I sold three As earlier this year, and reinitialized their HDDs using a Gotek and I don't recall seeing the same. If you want to post the Fluke rom firmware version you have, gotek firmware variant/version and md5sum of each hfe image and I'll see if I can reproduce but It may take me a while as all my remaining As have dead screens and I'll have to take a screen off an FT. Tony _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
You used the FF.CFG that I sent you? I'll email you the actual contents of the USB drive I use. Its write protected. I see there is a Test Floppy Disk option in service disk 1.4 but it's not
Not that I am aware of. Unrelated but FYI. Switching to Canon will likely cause issues with drive being detected due to !CHG being on pin 16, Shugart spec is CHG on pin 2. See my old post. Canon drives and Canon firmware actually seems to implement the disc change detect test in the service manual, Sony ignores it. Which is why sometimes you see grounding pin 16 mentioned. _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
I just tested with the following configuration. I am able to boot from the 3 system floppy images without issue. Best guess at this point, try upgrading to 4MB RAM. Maybe it's a requirement for V5.0. I've never seen a system with less than 4MB. Tony --------------------------------------------------------------------- Fluke 9100A. Mainboard rev H 4MB System RAM ROM version 5.0 Floppy drive type: Sony F17 Disc Error reporting: on Gotek running FlashFloppy firmware version 2.14 $ cat FF.CFG host = fluke write-protect = yes $ md5sum *.hfe 462ce16ae015aef52fcf45ed43c797ad *master60_1.hfe fb801cad7ba43a6b12f68fa4872ee9b4 *master60_2.hfe e2b9d9c9bf083b271b34314f4d655827 *svc1.4.hfe d4b5b47ea9501dd7375498d1474e5514 *sys61_1.hfe 165cc387db4103b867277e74afacc02e *sys61_2.hfe 654f2cec1e6a0e6655aefd04a7b38b27 *sys61_3.hfe _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Hi, I have a rev G. board but the rest is the same. The extra 2Mb SIMMS are on their way, I will report back when they will be installed. Thanks for your help ! Marc ________________________________ De : Tony Jones <tony@tonyjones.com> Envoyé : 19 mars 2020 13:05 À : Technical Tools Mail List <techtoolslist@flippers.com> Cc : Marc Desfossés <mdesfoss@hotmail.com> Objet : Re: [Techtoolslist] Fluke 9100A - Cannot boot from system disks I just tested with the following configuration. I am able to boot from the 3 system floppy images without issue. Best guess at this point, try upgrading to 4MB RAM. Maybe it's a requirement for V5.0. I've never seen a system with less than 4MB. Tony --------------------------------------------------------------------- Fluke 9100A. Mainboard rev H 4MB System RAM ROM version 5.0 Floppy drive type: Sony F17 Disc Error reporting: on Gotek running FlashFloppy firmware version 2.14 $ cat FF.CFG host = fluke write-protect = yes $ md5sum *.hfe 462ce16ae015aef52fcf45ed43c797ad *master60_1.hfe fb801cad7ba43a6b12f68fa4872ee9b4 *master60_2.hfe e2b9d9c9bf083b271b34314f4d655827 *svc1.4.hfe d4b5b47ea9501dd7375498d1474e5514 *sys61_1.hfe 165cc387db4103b867277e74afacc02e *sys61_2.hfe 654f2cec1e6a0e6655aefd04a7b38b27 *sys61_3.hfe _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Hi Ian,
I usually write them with dtc these days, but have used ImageDisk in DOS with success as well. It sounds like your media may be faulty, even though it was unused. -- Ian _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
why would you be usings sams disk? your name is marc? On Tue, Mar 17, 2020 at 9:47 AM Marc Desfossés <mdesfoss@hotmail.com> wrote:
Hi Ian,
Thanks
Marc
Hi,
Brandon C -
Marc Desfossés -
Tony Jones -
Tony Jones via Techtoolslist
