Fluke 9100A - Cannot boot from system disks
Hi, I am trying to setup a 9100A unit. The initial hard disk was defective. I had a "missing hard drive" error message. I've upgrade the roms to the V5 version and setup a SCSI2SD drive. I was able to format the disk with service disk 1.4 Whenever I try to boot from the system disks (tried original disks 4.1, images from 6.0 and 6.1), I get an error: Error 243 loading /dd/rom/appl I can skip it but then then I get more errors: root: appl missing root: Can't start application Path Name not found And the unit freezes at Initializing system. Error 243 is a CRC error based on the documentation. The floppy drive seems fine since I can load service disk 1.4. I thought that I did not restore the images properly but since I also get the error with original 4.1 disks, I am not sure what I can try next. Did anyone have had a similar problem ? Thanks Marc _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Hi Marc A member on here uploaded a V6_1 image to the FTP which is complete and ready to go. it is located here: ftp://ttl.arcadetech.org/TTL/Test_Equipment/Fluke/9100%20Series/v6_1-Disk_Image.rar Unzip it and use winimage to write it to your SD card.. On Sun, 15 Mar 2020 at 17:10, Marc Desfossés <mdesfoss@hotmail.com> wrote:
Hi,
Thanks
Marc
Thank Steve. I did that yesterday and the machine works fine. Just not sure what is going on with the disk/image. I will try with a Gotek to see if the drive is the problem. Marc ________________________________ De : Techtoolslist <techtoolslist-bounces@flippers.com> de la part de Steve Larkins <steve@ukaudiovisual.co.uk> Envoyé : 16 mars 2020 11:50 À : Technical Tools Mail List <techtoolslist@flippers.com> Objet : Re: [Techtoolslist] Fluke 9100A - Cannot boot from system disks Hi Marc A member on here uploaded a V6_1 image to the FTP which is complete and ready to go. it is located here: ftp://ttl.arcadetech.org/TTL/Test_Equipment/Fluke/9100%20Series/v6_1-Disk_Image.rar Unzip it and use winimage to write it to your SD card.. On Sun, 15 Mar 2020 at 17:10, Marc Desfossés <mdesfoss@hotmail.com> wrote:
Hi,
Thanks
Marc
_______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Marc Desfossés -
Steve Larkins
