Fluke 68000 Pod Problem
Just got a 68000 and tried to self-test and comes back with "POD SELF TEST 68000 FAIL 00". Any help with this error? Also, does anyone fix Fluke Pods? _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Did you make sure the CPU cable was secured in the texttool slot on the pod? William Stillwell Hamster / KI4SWY Stillwell Software Solutions. Free Play Florida Arcade & Pinball Show Organizer -----Original Message----- From: Techtoolslist [mailto:techtoolslist-bounces@flippers.com] On Behalf Of Theron Troxel via Techtoolslist Sent: Monday, July 6, 2015 3:02 PM To: Technical Tools Mail List Cc: Theron Troxel Subject: [Techtoolslist] Fluke 68000 Pod Problem Just got a 68000 and tried to self-test and comes back with "POD SELF TEST 68000 FAIL 00". Any help with this error? Also, does anyone fix Fluke Pods? _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
That did it! Thanks for the quick response. I had one pin that was cut in half and thought it was making a good connection. I soldered on a little bit of an extension and now pod passed self test. Does anyone repair these? I have 6809 that might need some help. I would have to test it a little bit more to make sure. On Monday, July 6, 2015 2:11 PM, William Stillwell <wkstill@franz-family.com> wrote: Did you make sure the CPU cable was secured in the texttool slot on the pod? William Stillwell Hamster / KI4SWY Stillwell Software Solutions. Free Play Florida Arcade & Pinball Show Organizer -----Original Message----- From: Techtoolslist [mailto:techtoolslist-bounces@flippers.com] On Behalf Of Theron Troxel via Techtoolslist Sent: Monday, July 6, 2015 3:02 PM To: Technical Tools Mail List Cc: Theron Troxel Subject: [Techtoolslist] Fluke 68000 Pod Problem Just got a 68000 and tried to self-test and comes back with "POD SELF TEST 68000 FAIL 00". Any help with this error? Also, does anyone fix Fluke Pods? _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
The usual problems with the pods is the 40 (or whatever count) pin cpu cable gets a break inside. Unfortunately there are no schematics of the cables that I know of - a number of the pods use the same cable, but there are others (all are 40 pin) that use different cables. See my list on: http://flippers.com/fluke.html If anyone has taken the time to figure out the differences between the various 40 pin cables please post here and I'll add it to the list. I suspect the main differences are the different ground connections when using shielded cables. If that is the only difference then folks can make up their own short cables (if they can't do twisted pair shielding), or check with Shy at Navatek.com as he has a lot of Fluke parts that he bought when the factory was clearing out old stock. I have the test fixtures for a few of the pods, but no time to service any, nor parts - perhaps Shy also fixes pods?? I'd start with him... John :-#)# On 07/06/2015 1:05 PM, Theron Troxel via Techtoolslist wrote:
-- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Hi, first of all 68000 POD manual distinguish from defective POD from an inoperative one, your case is the first So, first download the .PDF manual here: https://isurplus.com.au/manuals/Fluke%209000A-68000%20User%20Manual.pdf and start reading from chapter 6-1.In particual after display the "POD SELF TEST 68000 FAIL 00" message you have to perform the enhanced test by performing a read operation at address F000 0000.If the message resulting from this red operation is anything other tahn READ @ F000 000 = FF OK, the the pod failed the enhanced self test.Continue reading chapter 6.6. Il 06/07/2015 21:02, Theron Troxel via Techtoolslist ha scritto:
--- Questa e-mail è stata controllata per individuare virus con Avast antivirus. https://www.avast.com/antivirus _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Fabrizio Vasile -
Theron Troxel via Techtoolslist -
