What type of software do you guys use when interfacing the 9010A to a computer via a 232 port? Is there any software that will run on an old 386 computer? Thanks, Kev To UNSUBSCRIBE from techtoolslist, send a message with "UNSUBSCRIBE" in the message body to: techtoolslist-request@flippers.com. Please direct other questions, comments, or problems to jrr@flippers.com.
I think the standard is 9LC.EXE and RKSIC.EXE. If you don't have them let me know and I'll see if I can send them to you. They run under all the old DOS versions, and *sometimes* they run OK on Windows platforms. Alex ----- ayeckley@elektronforge.com www.elektronforge.com To UNSUBSCRIBE from techtoolslist, send a message with "UNSUBSCRIBE" in the message body to: techtoolslist-request@flippers.com. Please direct other questions, comments, or problems to jrr@flippers.com.
I have no problems with those programs under Windows 2K...I should leave them on my download section for the fluke on flippers. I'll post them later today and provide a link. Does anyone know of a free FTP hosting site where we can store these things for others to grab? I don't have time to research that...I only have about ten megs free on my site and a large email can suck that dry... John :-#)# At 10:15 AM 02/02/2002 -0500, Alex Yeckley wrote:
I'm tempted to let you use space on my site if you are interested. My only concern is that I don't have much time to maintain it... Alex ----- ayeckley@elektronforge.com www.elektronforge.com To UNSUBSCRIBE from techtoolslist, send a message with "UNSUBSCRIBE" in the message body to: techtoolslist-request@flippers.com. Please direct other questions, comments, or problems to jrr@flippers.com.
What if you set up a simple anonymous FTP site? If only members of this list knew of it that would be fairly secure. We could upload and download scripts and programs only related to the 90XX. I am thinking of moving flippers.com to a new host as Jumpline seems to be down a lot..I have been promised lots more space for the same $$...then the FTP would be no problem for this group. John :-#)# At 11:51 AM 02/02/2002 -0500, Alex Yeckley wrote:
At 14:13 02-02-02 , you wrote: Yes Try TELIX Dos based software it's Ideal for the job I use it all the time if you don't have it drop me a line Off-list. I have attached a 1k plain text file of operating instructions should anyone else on the list need them. Regards Pete (Invadar)
Thanks, Kev
Fluke ? PC Transfer Setup (should match settings on the Fluke) PC Run Telix Set Parameters 9600 Baud, no parity, 8 data bits, 1 stop bit Alt-O Terminal Options J,K,L - ON C - TTY Fluke ? PC Transfer Fluke Load program/tape into Fluke memory. Press AUX I/F PC ALT - R Protocol prompt - ASCII "Enter file name" Press Return Fluke If you want an ASCII file (i.e. printer format), press PROG on Fluke. Fluke If you want BINARY FORMAT (Fluke executable format), press WRITE on Fluke. PC ? Fluke Transfer Setup as before PC ALT - S Select ASCII protocol Select the desired file and press the RETURN key once to put selected file in "Tagged Files" box. Fluke Press AUX I/F Press READ At the "Are you sure" prompt hit YES. "Aux Receiving" prompt. PC Press F10 If all's well the line indication at the bottom left of the status bar should be incrementing.
Hi Peter, Send me a copy of that and I'll put it up on the FTP server and provide a link... John :-#)# At 04:25 PM 05/02/2002 +0000, Invadar \"Peter Davies\" wrote:
Yes Try TELIX Dos based software it's Ideal for the job I use it all the time if you don't have it drop me a line Off-list. I have attached a 1k plain text file of operating instructions should anyone else on the list need them. Regards Pete (Invadar) ...
Hi John, Still in Aberdeenshire uk not such a new boy tho. Have been around quite a while bought a space panic from you about six or seven years ago. you seem to have my correct email address which is for confirmation invadar@mean-machine.org.uk I have got your email of today requesting I send you TELIX software and will dig it out this evening and send it. regards pete At 17:54 05-02-02 , you wrote:
Anyone know Brendan Keith's new email or the new guy Peter Davies (supposedly Invadar@mean-machine.org.uk) as their email addresses are bouncing...
John's Jukes Ltd. 2343 Main St., Vancouver, BC, Canada V5T 3C9 Call (604)872-5757 or Fax 872-2010 (Pinballs, Jukes, Video Games) http://www.flippers.com "Old pinballers never die, they just flip out."
Also getting ade@arcadestuff.thedvdproject.com bouncing back...Anyone know who that is? Here is the error message: ------------------------------------------------------------------------------------------------------ This is the Postfix program at host jupiter.easily.co.uk. I'm sorry to have to inform you that the message returned below could not be delivered to one or more destinations. For further assistance, please send mail to <postmaster> If you do so, please include this problem report. You can delete your own text from the message returned below. The Postfix program <ade@arcadestuff.thedvdproject.com>: host arcadestuff.thedvdproject.com[80.94.192.12] said: 550 not local host arcadestuff.thedvdproject.com, not a gateway Reporting-MTA: dns; jupiter.easily.co.uk Arrival-Date: Tue, 5 Feb 2002 20:23:55 +0000 (GMT) Final-Recipient: rfc822; ade@arcadestuff.thedvdproject.com Action: failed Status: 5.0.0 Diagnostic-Code: X-Postfix; host arcadestuff.thedvdproject.com[80.94.192.12] said: 550 not local host arcadestuff.thedvdproject.com, not a gateway Received: from server8000.net (unknown [209.239.41.23]) by jupiter.easily.co.uk (Postfix) with ESMTP id 209D0841B for <ade@arcadestuff.com>; Tue, 5 Feb 2002 20:23:55 +0000 (GMT) (more deleted) -------------------------------------------------------------------------------------- John :-#(# To UNSUBSCRIBE from techtoolslist, send a message with "UNSUBSCRIBE" in the message body to: techtoolslist-request@flippers.com. Please direct other questions, comments, or problems to jrr@flippers.com.
On the subject of Fluke 9010 RS-232 .... I'm still looking for an RS232 card for my 9010 as it does not have one. If anyone has one from a dead unit or otherwise I'll buy it! My tape drive does not work either so I'm looking for one of those too. This is really annoying as I'm effectively limited to manual use as I can download or save any programs :o( Instead of the RS232 interface it's got a surface mount PCB installed which is labelled "option -006 Async Sig" what is this for? Dave Langley www.robotron-2084.co.uk To UNSUBSCRIBE from techtoolslist, send a message with "UNSUBSCRIBE" in the message body to: techtoolslist-request@flippers.com. Please direct other questions, comments, or problems to jrr@flippers.com.
Isn't that the 3rd plug on the front for Clock Module & signatures? Mine doesn't have that..... Kev mowerman@erols.com To UNSUBSCRIBE from techtoolslist, send a message with "UNSUBSCRIBE" in the message body to: techtoolslist-request@flippers.com. Please direct other questions, comments, or problems to jrr@flippers.com.
That is the Signature Analyzer Option board. You need the tape for it...and the interface box. John :-#)# At 06:52 PM 05/02/2002 +0000, Dave Langley wrote:
Since my tape drive does not work I really need to get a replacement for it or fix it. Has anyone ever repaired a fluke 9010 tape drive? I'm still looking for an RS232 card too ... Dave Langley www.robotron-2084.co.uk To UNSUBSCRIBE from techtoolslist, send a message with "UNSUBSCRIBE" in the message body to: techtoolslist-request@flippers.com. Please direct other questions, comments, or problems to jrr@flippers.com.
Hi Dave, One problem I found with the tape drives is the drive belt. You should be able to pick a similar belt at a TV/VCR repair shop. You will need to take the drive with you to size it. If anyone needs one and can't find it I am willing to make a run to my local wholesaler and pick up a pack of them, but there is a charge for that part as a result...time... You can also remove the tape drive and set it on top of the 9010 to see if it works and run the tests as covered in the Fluke service manual that is stored on http://www.spies.com/arcade/TE/index.html (Thanks to Al Kossow for archiving this!) John :-#)# At 06:53 PM 06/02/2002 +0000, Dave Langley wrote:
Hello, I was trying to print the 9010 manuals in PDF on spies and found that they are printing black background and white text (negative image). I have not found how to switch them around. Has anyone else had this problem? Thanks, Kevin To UNSUBSCRIBE from techtoolslist, send a message with "UNSUBSCRIBE" in the message body to: techtoolslist-request@flippers.com. Please direct other questions, comments, or problems to jrr@flippers.com.
Printed fine for me. Must be your setting on Acrobat (you are using acrobat reader?)
Hello,
Kevin
Check your printer settings in Acrobat. AIR you can't print them as an image...or is it the other way around? One way makes the black background... John :-#)# At 09:03 AM 08/02/2002 -0500, Kevin wrote:
Hello,
Kevin
There is a setting in Acrobat for that such thing. Funny thing is, I accidentally printed to the our color printer here and it was normal. Once I switched to the laser printer I wanted to use (no settings changes in Acrobat mind you), it was reverse imaged. Annoying it was - seemed to be a difference in printer defaults also. Anyway, the Acrobat setting should fix it. Greg John Robertson wrote:
Hello,
Kevin
I found I needed to use the latest version of reader. I was using a Acrobat 4. ----- Original Message ----- From: "John Robertson" <jrr@flippers.com> To: <TechToolsList@flippers.com>; <TechToolsList@flippers.com> Sent: Friday, February 08, 2002 10:50 AM Subject: Re: Fluke 9010A manuals on Spies?
Hello,
Kevin
I had this problem on a laser jet 4+ cured it by going to the printer options window and checking the box that says print as image. worked fine as long as i did that. Acrobat v 5 seems to have corrected it as i don't have to do it using ver 5 Regards pete(invadar) At 15:50 08-02-02 , you wrote:
Hello,
Kevin
I have created a directory for some fluke stuff: a couple of experimental scripts, Pod ROMs, 9010 ROMs, compilers, and DOS/Windows (in a DOS window) operating software. I can put about 3 megs in there so if anyone has stuff to add email it to me for uploading... check here: http://www3.tulus.net/Flippers/Fluke for the files... John :-3)# To UNSUBSCRIBE from techtoolslist, send a message with "UNSUBSCRIBE" in the message body to: techtoolslist-request@flippers.com. Please direct other questions, comments, or problems to jrr@flippers.com.
Gah! TYPO! Please use the following link: http://www3.telus.net/Flippers/Fluke That works. I just tested it... John :-#(# At 12:46 PM 05/02/2002 -0800, John Robertson wrote:
check here: http://www3.tulus.net/Flippers/Fluke <--bad link, don't try this...) for the files...
After searching for awhile for a 6809 pod I finally bought one from a dealer. Best price I could find after bargining $450. Anyone interested drop me a line..... Kev To UNSUBSCRIBE from techtoolslist, send a message with "UNSUBSCRIBE" in the message body to: techtoolslist-request@flippers.com. Please direct other questions, comments, or problems to jrr@flippers.com.
Greetings all; Up untill recently my most involved task with video/pinball games have been Cap Kits and replacing Data East power driver board connectors. I have always deffered board repairs to others more qualified. That is till now. I recently purchased a Fluke 9010A with 6502 and Z80 pods from a fellow collector who needed cash and who like me is completely self taught. He convinced me that I could repair boards myself given a little hard work and patience. Now this may have just been part of his sales pitch, but I believed him & bought it. I met Kev a couple years ago & have stayed in touch. He gave me this list to subscribe to. Either in hopes I would come here instead of sending him 100's of emails full of newbish questions, or to generate conversation here. :) I have no background in electronics and everything I do know, I have picked up from working on my own collection of Arcade games & Pinballs the past couple of years. I am probably the last guy who should own a Fluke & should really pass it on to someone who will get better use of it. But before I do that, I would like to see if I can make some small use of it. To compound matters, I picked up a second Fluke 9010A base unit off of ebay. And herein lies my first question. The Ebay one has a digit going out, it flickers, gets real dim, then comes back. The plus side is that it has a RS232 port on it, my original one does not. Can I easily swap the RS232 to my original unit? I havent taken the cover off to see if its just a card or if its hardwired in. Second question concerns Oscilliscopes. First of I know I need one, How do I know? I have been told I do :). I do know I can display the output of Vector games on one that has XY inputs on it. What other uses for it, I am very vague on, but am willing to learn. The problem I am running into is knowing which units have XY inputs and which ones dont. I have been mainly looking at Ebay auctions & while they list alot of features, only one scope have I found so far has actually listed XY inputs ( a TEK 465M). Is there some other name this feature goes by that I am unaware of? Kev has been very patient & helpful, but I dont want to wear out my welcome in his inbox :) So I bring my questions here & hope my lack of knowledge is not to embarrassing apparent. I have picked up a few books & my Fluke came with a 4 cd set instruction set that I have just begun. ANY help would be greatly appreciated. Thanks for your time Randy To UNSUBSCRIBE from techtoolslist, send a message with "UNSUBSCRIBE" in the message body to: techtoolslist-request@flippers.com. Please direct other questions, comments, or problems to jrr@flippers.com.
Welcome Randy! Yes, you can just swap the RS-232 card, it's easy. As for 'scopes, well we have an old dual trace one at the shop, I doubt it is faster than 40 megs and seems to do just fine if it is thumped correctly. My tech never uses the thing. He uses a logic probe and the Fluke for fixing most of his boards. The memory test, BUS test and ROM test grab about 90% of the problems, and it is a bit of scouting to get the remaining problems... Radio Shack had a good book on service theory, or SAMS Photofacs(?) publishes a few that are great for beginners. I've been beating games up since the 70's and I'm self taught...no courses in game repair back then. John :-3)# At 08:34 PM 08/02/2002 -0500, Randy Bissett wrote:
Greetings all; ... To compound matters, I picked up a second Fluke 9010A base unit off of ebay. And herein lies my first question. The Ebay one has a digit going out, it flickers, gets real dim, then comes back. The plus side is that it has a RS232 port on it, my original one does not. Can I easily swap the RS232 to my original unit? I havent taken the cover off to see if its just a card or if its hardwired in.
While there's all this great talk of 9010A's and stuff, thought I'd ask, does anyone have a 9010A probe that they'd like to sell or trade? I have a 9010A, and a semi-broken Z80 pod I am fixing, and intentions to actually use it to fix something :) I believe I need the little logic-probe looking thing that plugs into the DB9 socket on it to use it properly. I have many things to trade, parts, game boards, test equipment, etc, so if you have one, give me an email and we can work something out. If you have any spare pods I'd be interested too! Thanks a lot, Marc Alexander www.laserarcade.com To UNSUBSCRIBE from techtoolslist, send a message with "UNSUBSCRIBE" in the message body to: techtoolslist-request@flippers.com. Please direct other questions, comments, or problems to jrr@flippers.com.
Ouch! Did you even get a kiss? ;-)
participants (10)
Alex Yeckley -
Dave Langley -
Greg -
Invadar "Peter Davies" -
Kev -
Kevin -
Marc Alexander -
Mark Shostak -
Randy Bissett
