HP1660C/CS/CP Logic Analyzer information on upgrades? Floppies?
Anyone using one of these beasties? It is quite powerful allowing up to 68 channels (136 channels on the 1660) at 100MHz. I don't think there are many modern USB devices that can come anywhere close to competing. Mine is the 1662C with four pods and 2MBx32 RAM, I'm going to upgrade it to 8MB in the hopes that will give me more than 4K of storage. I am curious about other upgrades that were available for the machine, but have not found any discs archived nor manuals other than what I've posted on TTL under HP. There seems to be some sort of upgrade that allows one to connect the HP166X to a PC and run the machine via that - which should be easier than poking away at the keyboard on the machine. Agilent/HP marketed a number of LAs using similar numbers and the same control panel and look & feel of the operation. Anyone have any discs they want to copy and share? There must be a few of us using this tool still... List of options (from the flyer): _Additional HP 1660C/CS/CP Series Product Options _ Option 015 Ethernet LAN interface [13] Option 0B1 Extra User Manual Option OB3 Add Service Manual Option OBF Add Programming Manual Option 908 Rack Mount Kit Option UK9 Front Panel Cover Option W30 3-Year extended repair service Option W50 5-Year extended repair service _HP 1660CP Series Required Product Options _ Option 011 TTL Clock Pod and Lead Set (1 ea 10460A + 1 ea 10474A) Option 012 3-state TTL/3.3V Data Pod and Lead Set (1 ea 10466A + 1 ea 10474A) Option 0133-state TTL/CMOS Data Pod and Lead Set (1 ea 10462A + 1 ea 10474A) Option 014 TTL Data Pod and Lead Set (1 ea 10461A + 1 ea 10474A) Option 021ECL Clock Pod and Lead Set (1 ea 10463A + 1 ea 10474A) Option 022 ECL (terminated) Data Pod and Lead Set (1 ea 10464A + 1 ea 10474A) Option 023 ECL (unterminated) Data Pod and Lead Set (1 ea 10465A + 1 ea 10347A) ________________________________________________________________ Note: For the pattern generator of HP 1660CP-series, please order at least one clock pod and at least one data pod for every eight (8) output channels from the above options or accessories listed on page 12. _HP 1660C/CS/CP Series Upgrades _ HP E2460CS [12] Upgrade to add two-channel 1-GSa/s, 250-MHz BW oscilloscope to any of theHP 1660CS series (oscilloscope upgrade does not apply to HP 1660A-series) HP E2495A [12] Upgrade to add 32-channel, 200 M Vectors/sec pattern generator (this upgrade does not apply to the HP 1660CS-series and HP 1664A) HP E2427B Add keyboard with DIN connector (PC style) HP E2427A Add keyboard with HIL connector (HP 1664A only) HP E2472A [12] Upgrade to add LAN capability to HP 1660C/CS series (this upgrade does not apply to the HP 1664A) HP E2460B† [12] Upgrades HP 1661C/CS to 136-channel HP 1660C/CS model, option 001 upgrades channel count of HP 1662C/CS to 1660C/CS, option 002 upgradeschannel count of HP 1663C/CS to 1660C/CS HP E2461B† [12] Upgrades HP 1662C/CS to 102-channel 1661C/CS model, option 001 upgrades channel count of 1663C/CS to 1661C/CS HP E2462B† [12] Upgrades HP 1663C/CS to 64-channel 1662C/CS model HP E2469A [12] Upgrade HP 1660A/AS series to HP 1660C/CS series (includes LAN capability—do not order additional HP E2472A) _Accessory Software_ HP B3740A Software Analyzer Opt AJ4 IBM, 3.5" Media/Documentation HP 9000 Series 700 Media/Documentation Opt AAY SUN (Solaris and SUN OS) Media/Documentation Opt AAV IBM Single User License Opt UDY Opt UBY HP 9000 Series 700 Single User License Opt UBK SUN (Solaris and SUN 0S) Single User License HP 10391B Inverse AssemblerDevelopment Package _________________________________________________________________________________ [12] Upgrade includes cost of installation at a Hewlett- Packard Service Center. Upgrade is not customer installable. [13] Ethernet LAN interface is included standard on the HP 1660CP-series and HP 1670D-series models. LAN is optional on the HP 1660C-series and HP 1660CS-series. LAN is not available on theHP 1664A. † Channel count upgrades do not apply to theHP 1664A. _________________________________________________________________________________ Thanks! John :-#)# -- John's Jukes Ltd. 7 - 3979 Marine Way, Burnaby, BC, Canada V5J 5E3 Call (604)872-5757 (Pinballs, Jukes, Video Games) flippers.com "Old pinballers never die, they just flip out" _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
On 2023/04/14 12:09 p.m., David Shoemaker wrote:
I have a one, used it a couple of times. It's just cumbersome to set up the names. I connect to it over x windows to get a better keyboard and display from my windows machine.
Most of the time I am using a cheep saleae clone usb based analyzer. I only get 16 channels vs the hp's 128 but the simplicity of capture is a benifit.
Thanks for the tip about X-Windows. Found a discussion on eevblog on that topic: https://www.eevblog.com/forum/testgear/hp1660-logic-analyser-and-communicati... John :-#)# -- John's Jukes Ltd. 7 - 3979 Marine Way, Burnaby, BC, Canada V5J 5E3 Call (604)872-5757 (Pinballs, Jukes, Video Games) flippers.com "Old pinballers never die, they just flip out" _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
I use my 169xx frames with windows 7, much easier to use, the 166x were nice for xwindow control, i use my 166x still with my HP Preprocessors, as i have yet to migrate them over to the new 169xx as it will require some coding. William Stillwell On Fri, Apr 14, 2023 at 3:24 PM John Robertson via Techtoolslist < techtoolslist@flippers.com> wrote:
I have been trying to figure out how to write some post processing, I think it would be handy to say record everything happening at the state machine prom of a tempest board and "disassemble" the vector engine as it runs, for those really weird errors where like one vector instruction is broken. -----Original Message----- From: Techtoolslist <techtoolslist-bounces@flippers.com> On Behalf Of William Stillwell Sent: Friday, April 14, 2023 12:53 PM To: jrr@flippers.com; Technical Tools Mail List <techtoolslist@flippers.com> Subject: Re: [Techtoolslist] HP1660C/CS/CP Logic Analyzer information on upgrades? Floppies? I use my 169xx frames with windows 7, much easier to use, the 166x were nice for xwindow control, i use my 166x still with my HP Preprocessors, as i have yet to migrate them over to the new 169xx as it will require some coding. William Stillwell On Fri, Apr 14, 2023 at 3:24 PM John Robertson via Techtoolslist < techtoolslist@flippers.com> wrote:
https://www.eevblog.com/forum/testgear/hp1660-logic-analyser-and-commu nicating-through-x-windows-setup/
On thr 16900 frame, adding option 100 grants you to run the protocol analyzer which should allow you to do that. On Fri, Apr 14, 2023, 5:48 PM <davids@oz.net> wrote:
-----Original Message----- From: Techtoolslist <techtoolslist-bounces@flippers.com> On Behalf Of William Stillwell Sent: Friday, April 14, 2023 12:53 PM To: jrr@flippers.com; Technical Tools Mail List < techtoolslist@flippers.com> Subject: Re: [Techtoolslist] HP1660C/CS/CP Logic Analyzer information on upgrades? Floppies?
davids@oz.net -
John Robertson via Techtoolslist -
