My 9010 started making a weird pulsing noise which I tracked down to the fan. Like it was trying to start but couldn't. I've never given the fan any thought before, does it run all the time? It's just two wires off the motherboard (which weren't pulsing per my scope) but these go to some kind of fan sending unit which feeds 4 wires to the physical fan. Is this some kind of temperature control? The fan blades didn't spin easily, quite a bit of resistance so I was assuming the fan itself was the problem rather than the sending unit. I have the model# specs for the fan so I'll look for a replacement but that might be challenging, replacing just the fan part and connecting to the existing grey sending unit may be another option. I couldn't find any previous mention of this in the archives, curious if anyone has been here before? Thanks! Tony _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
I honestly haven't looked at it, so I can't comment on the wiring situation. But on the fan itself, is it the type you can peel the label back exposing the end of the bearing or bushing, and put a drop or two of light oil in the cavity to re-hydrate and free things up, giveing it some new life? ----- Original Message ----- From: "Tony Jones" <tony@tonyjones.com> To: "Technical Tools Mail List" <techtoolslist@flippers.com> Sent: Thursday, July 14, 2016 12:24:00 PM Subject: [Techtoolslist] 9010 fan question My 9010 started making a weird pulsing noise which I tracked down to the fan. Like it was trying to start but couldn't. I've never given the fan any thought before, does it run all the time? It's just two wires off the motherboard (which weren't pulsing per my scope) but these go to some kind of fan sending unit which feeds 4 wires to the physical fan. Is this some kind of temperature control? The fan blades didn't spin easily, quite a bit of resistance so I was assuming the fan itself was the problem rather than the sending unit. I have the model# specs for the fan so I'll look for a replacement but that might be challenging, replacing just the fan part and connecting to the existing grey sending unit may be another option. I couldn't find any previous mention of this in the archives, curious if anyone has been here before? Thanks! Tony _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Thanks!
Tony Depending the fan design there may be a removable rubber seal under the fan label (if in the middle of the fan). I peel back the label, remove the seal and then put a couple of drops of synthetic motor oil (around 20W) and let it soak in a while then spin the fan manually back and forth to work the it back into the bushings. Then seal it back up.
Usually works for years afterwards... John :-#)# _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
No, not on this fan.
You can always paypal me a $20 bill and I can send you a working tested fan ...... Art -----Original Message----- From: Techtoolslist [mailto:techtoolslist-bounces@flippers.com] On Behalf Of Tony Jones Sent: Thursday, July 14, 2016 2:11 PM To: John Robertson; Technical Tools Mail List Subject: Re: [Techtoolslist] 9010 fan question On Thu, Jul 14, 2016 at 10:43 AM, John Robertson <jrr@flippers.com> wrote:
No, not on this fan. _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Sometimes the label is on the mounted side of the fan so you have to take it out to see it. Apologies if you already did that... I support technology in my day job (I'm 'working' as I type this) so at least I didn't ask you if your computer was plugged in. 😃 -------- Original message -------- From: Tony Jones <tony@tonyjones.com> Date: 7/14/16 12:10 PM (GMT-07:00) To: John Robertson <jrr@flippers.com>, Technical Tools Mail List <techtoolslist@flippers.com> Subject: Re: [Techtoolslist] 9010 fan question On Thu, Jul 14, 2016 at 10:43 AM, John Robertson <jrr@flippers.com> wrote:
Seems fully sealed front back to me. I just kindly took up Art on his offer. Easy peasy. Appreciate your "i'm trying to not treat you like a blithering idiot" :-) Thanks Tony On Jul 14, 2016 12:55 PM, "Jess Askey" <jess@askey.org> wrote:
-------- Original message -------- From: Tony Jones <tony@tonyjones.com> Date: 7/14/16 12:10 PM (GMT-07:00) To: John Robertson <jrr@flippers.com>, Technical Tools Mail List < techtoolslist@flippers.com> Subject: Re: [Techtoolslist] 9010 fan question
$150? Free shipping Thanks Art PS - I don't remember if FS is ok here - holler if not and I won't do it again -----Original Message----- From: Techtoolslist [mailto:techtoolslist-bounces@flippers.com] On Behalf Of Tony Jones Sent: Thursday, July 14, 2016 4:41 PM To: Technical Tools Mail List Subject: Re: [Techtoolslist] 9010 fan question Seems fully sealed front back to me. I just kindly took up Art on his offer. Easy peasy. Appreciate your "i'm trying to not treat you like a blithering idiot" :-) Thanks Tony On Jul 14, 2016 12:55 PM, "Jess Askey" <jess@askey.org> wrote:
Riptor/Twisty Wrist sells 2114 Ram @ 2.89 Each Qty 1. I think 150 is a little on the high side. William Stillwell Hamster / KI4SWY Free Play Florida Arcade & Pinball Show Organizer On Tue, Jul 26, 2016 at 4:57 PM, Art <art@artfromny.com> wrote:
$150? Free shipping
Thanks
Art
Thanks
Hi Everyone, No component sales please, if you are selling or trading test gear that should be OK. John :-#)# On 07/26/2016 1:57 PM, Art wrote:
$150? Free shipping
Thanks
Art
Thanks
Depending the fan design there may be a removable rubber seal under the fan label (if in the middle of the fan). I peel back the label, remove the seal and then put a couple of drops of synthetic motor oil (around 20W) and let it soak in a while then spin the fan manually back and forth to work the it back into the bushings. Then seal it back up. No, not on this fan.
-- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist
Sorry John my fault for not asking first - feel free to pull the email off if that is something you can, and want, to do Art -----Original Message----- From: Techtoolslist [mailto:techtoolslist-bounces@flippers.com] On Behalf Of John Robertson Sent: Tuesday, July 26, 2016 5:21 PM To: Technical Tools Mail List Subject: Re: [Techtoolslist] FS 48 pieces NOS U214D20 static 4K RAM Hi Everyone, No component sales please, if you are selling or trading test gear that should be OK. John :-#)# On 07/26/2016 1:57 PM, Art wrote:
$150? Free shipping
Thanks
Art
Thanks
-- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Need to reach him about some old B&W monitor stuff . . . . . did business with him in the late 90s, early 00s .... can't find any emails going that far back Thanks Art -----Original Message----- From: Techtoolslist [mailto:techtoolslist-bounces@flippers.com] On Behalf Of Tony Jones Sent: Thursday, July 14, 2016 4:41 PM To: Technical Tools Mail List Subject: Re: [Techtoolslist] 9010 fan question Seems fully sealed front back to me. I just kindly took up Art on his offer. Easy peasy. Appreciate your "i'm trying to not treat you like a blithering idiot" :-) Thanks Tony On Jul 14, 2016 12:55 PM, "Jess Askey" <jess@askey.org> wrote:
Art -
Brad Gass -
Jess Askey -
Tony Jones -
