hi all.. I have a B&K 490, that i got in the UK, but now i've moved to the USA i need to run it on 110v... http://www.andysarcade.net/pix/DSC_2706.JPG The label indicates it may be switcahble internally between the two voltages.. but i opened it up and stuff is not easy to get to.. The schems in my manual only show 117vAC input, not even the 234v stated.. So.. anyone else done this? anyone seen both taps? i dont want to pull it apart further without knowing its actually possible, the frame is quite compacted with stuff. thanks! -- Andrew Welburn http://www.andys-arcade.com _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Doesn't look good: http://antelopearcade.com/files/BK-Precision%20CRT%20Rejuvenator/B%26K_490_C... but there's a hint that T1 (main transformer) comes in both 117V and 220V versions. Maybe the 220 you have has alternate taps. -DrG On Jul 10, 2014, at 8:01 PM, Andrew Welburn <andy@andysarcade.net> wrote:
hi all..
thanks!
On 07/10/2014 5:01 PM, Andrew Welburn wrote:
hi all..
thanks!
The 490B manual has taps on the transformer (close to the chassis) for setting the line voltage - page 3: ftp://ttl.arcadetech.org/TTL/Test_Equipment/B&K/ When did you move to this side of the pond? John :-#)# -- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Feb/Apr 2014. http://www.ukvac.com/forum/fs-andysarcade-moving-sale-listing_topic337174.ht ml Welcome to the US Andy :) -----Original Message----- From: Techtoolslist [mailto:techtoolslist-bounces@flippers.com] On Behalf Of John Robertson Sent: Thursday, July 10, 2014 11:10 PM To: techtoolslist@flippers.com Subject: Re: [Techtoolslist] B&K 490 power conversion On 07/10/2014 5:01 PM, Andrew Welburn wrote:
hi all..
thanks!
April 1st i moved over yes, thanks! Andrew Welburn http://www.andys-arcade.com On 10/07/2014 20:20, William Stillwell wrote:
Feb/Apr 2014.
Welcome to the US Andy :) [snip]
ok, i figured out the power conversion, and the wiring setup, made some photos too, Jon - feel free to put this onto the FTP in the BK directory :) http://www.andysarcade.net/pix/BK490convert.JPG enjoy! Andrew Welburn http://www.andys-arcade.com On 10/07/2014 17:01, Andrew Welburn wrote:
hi all..
thanks!
enjoy!
Done, thanks Andy! John :-#)#
hi all..
thanks!
Douglas Gauck -
