Did you check the power levels with the Fluke pod in? Seems like I heard that it draws more power than the CPU. Also, maybe you have a weak component in the CPU circuit, since adding the pod changes trace lengths, power loading, etc. does it not? -----Original Message----- Okay, thanks for all the suggestions, now for an update ........... As Alex said above, my power supply was indeed sagging somewhat as I just upped the voltage and the Bus Test then passed okay. However ....... I still can't run the board with the Fluke attached using Run UUT - all I get Seeing that has reminded me to add that the CPU socket has recently been replaced. _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist
Use a probe/wite/etc to ground the reset pin of the socket while doing the UUT Run test. The release it and see if the board comes up okay... On 4/15/05, Robert C. Bullock <rcbullock@cox.net> wrote:
Well, some success - seems that lowering the +5VDC line to +4.5VDC gets one boardset to run via the Fluke - the other one still won't play ball though. I'm wondering if it's something to do with the clock ..... the two resistors that interface with the 7404 at 7B and the crystal are, according to the schematics, supposed to be 330 ohms. However, on the boardset that WILL work via the Fluke they are both 150 ohms, yet on the boardset that won't work via the Fluke they are 330 ohms and 1K I don't feel like experimenting with swapping them out right now, but maybe this is the cause. _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist
Phil. This is your problem, change the resistors to 150ohm, I bet you it will work, I've had this about 5 times except once, on taito L-shape SI pcbs. Andy Welburn www.andys-arcade.com
-----Original Message----- From: techtoolslist-bounces@flippers.com [mailto:techtoolslist- bounces@flippers.com] On Behalf Of Phil Morris Sent: 15 April 2005 22:35 To: Technical Tools Mail List Subject: Re: [Techtoolslist] Space Invaders
I Googled for this but came up with zip. I'm looking for the system 9 memory map so I can build a test script for my dead Comet pinball. Checksums would be nice to have too. Can someone help? Mark Hooks ----- Original Message ----- From: "Andy Welburn" <warlords@punkass.com> To: "'Technical Tools Mail List'" <techtoolslist@flippers.com> Sent: Friday, April 15, 2005 6:14 PM Subject: RE: [Techtoolslist] Space Invaders
Phil.
Adam Courchesne -
Andy Welburn -
Mark Hooks -
Phil Morris -
Robert C. Bullock
