Got a scsi2sd adapter with 4gb card. Grabed the 6.1 image and used win32diskimg to write it to the sdcard. Opened up my 9100. Had v5.0 roms in it so didn't change them yet. Connected scsi and power to new adapter and it boots. With 6502 pod connected and the cable in selftest position when I boot it I am getting a message: "enable line causes timeout". The pod (6502) passed selftest: Main menu - pod - enter Any idea what that message means? Is there a real getting started guide out there? The one on ttl is more an unboxing guide than a new user guide. David :-)= _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
enabled line causing timout is normal if you press reset with the pod plugged into itself. Read the manuals.. thats all i can say, there's a lot of them, but its worth it, there is no quick guide, there's too much stuff to gloss over. Andrew Welburn http://www.andys-arcade.com On 11/01/2016 16:15, David Shoemaker wrote:
Believe Andrew ! Verstuurd vanaf mijn iPad
Op 12 jan. 2016 om 02:59 heeft Andrew Welburn <andy@andysarcade.net> het volgende geschreven:
On 11/01/2016 16:15, David Shoemaker wrote: Got a scsi2sd adapter with 4gb card. Grabed the 6.1 image and used win32diskimg to write it to the sdcard.
Andre Huijts -
David Shoemaker
