Was digging through my Fluke paper and found my original printed copy for the file called Fluke_9XXX Series Status.xls (on /Fluke page) and buried in the list was Fluke part number 9100A-030 9010A TO 9100A PROGRAM TRANSLATOR. We have the book (PN877696) archived on TTL, but where is the software? Other items on this list are also of interest: 9100A-020 TEST LANGUAGE CHECKER (only have the flyer on TTL) 9100A-904 SOFTWARE UPGRADE/W/PRG'MRS KIT V6.1 (nothing) 9100A-904K INCREMENT UPGRADE KIT/PRG'MR DISK V4.2A (nothing) More stuff listed too, of use for 9100A aficionados to track down...I have asked Shy, haven't heard back yet. John :-#)# -- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
John Robertson writes:
I thought for sure I saw this on the FTP, but maybe it was just the manual, and the FTP site seems to be down so I can’t check.
This is the DOS program which checks the syntax of your TL/1 programs. If you’re writing TL/1 code on a PC, it saves you the time downloading the code to the 9100 and checking the syntax there. This is on the FTP site, I think the name is TLC.EXE, but there isn’t an archival copy of the original disk.
This is the 6.1 upgrade kit for older mainframes with the programmer’s option, and consists of the 6.1 system disks and 6.1 programmer system disks. These are in the GitHub archive.
This is either an upgrade to 4.2 with the programmer option, or a more expensive upgrade to 6.1 for machines running older software. They might have cut people a break on price if they were going 6.0->6.1, but charged more if it was 4.2->6.1. The description sounds more like it’s an upgrade to 4.2A, but it seems odd that it would have the same p/n as the 6.1 upgrade. I don’t have any programmer disks older than 6.0, and would be interested in getting some. -- Ian _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Hi Ian, The active ftp site is ftp://ttl.arcadetech.org/TTL/Test_Equipment , it is up for me. It is messy, and I hope whoever volunteered to tidy up the Fluke section will get in touch with me again. Hmm, a TLC.EXE file is tucked away here: ftp://ttl.arcadetech.org/TTL/Test_Equipment/Fluke/9100%20Series/9100_TLC_Program_For_IBM_PC/ Thanks for that info, I will hunt my piles of discs, and old backups to see what appears. I also have a number of hard drives from my 6 x 9100As that I have never attempted to archive, so I think that is a project for the near future, who knows what is on them cause I don't! What I was hoping was one of the other documents would go into detail on the modifications made to the motherboard that upgraded it to 1.44 floppies - you have to have version 5.0 of the ROM installed too. John :-#)# On 2018/08/17 11:05 AM, Ian Eure wrote:
Hi Ian,
Yep... It was timing out trying to connect eariler, but seems to be working now.
Has anyone seen a 9100A with high density FDDs that operate in high density mode? I’ve seen UniSite programmers which had high density drives installed, but jumpered into DD mode so they’d work with the older controller on the mainboard. Looking at the schematics, it seems like the A and FT use nearly identical chipsets, and I see a DENS line wired up on the A, which would control or indicate the floppy density... So maybe it’s simply a matter of installing the 5.0 ROMs, 6.1 system, and a high density floppy drive. Probably easiest to start by swapping the disk from a FT into an A, setting the disk type with the service disk, and see what happens. -- Ian _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Hi Ian,
Looking at the schematics, it seems like the A and FT use nearly identical chipsets, and I see a DENS line wired up on the A, which would control or indicate the floppy density... So maybe it’s simply a matter of installing the 5.0 ROMs, 6.1 system, and a high density floppy drive. If you have Revision G motherboard then I expect you have the 1.44 upgrade done. Look for a bunch of jumpers on the underside.
If you want to update your MB to the G level allowing 1.44 Sony (?) floppies (& you need RV5.0 EPROM) then here are what I think are all the mods: 1) Cut traces @ W5, W6 and W7 2) Jumper W5 (connected to U27-P3) to U72-P9 (unused 7417 gate). 3) Jumper U72-P8 to W7 that connects to J14-P1 4) Jumper other side of W7 (ground) to W6 (side connected to J14-P4) 5) Jumper U27-P1 to U72-P5 (unused 7417 gate) 6) Jumper U72-P6 to J14-P16 (currently N/C) 7) Jumper W6 (connected to CHNG2 - J13-P1) to W5 (connected to J14-P2 - /SPARE) 8) for RV5.0 EPROM check that W2 is cut Photos: ftp://ttl.arcadetech.org/TTL/Test_Equipment/Fluke/9100%20Series/Photos/ I think that is all of them. I need to draw up the revised schematics, but no time! Will do that over the next day or two.. John :-#)#
Hi Ian,
Photos:
I have found a problem with the above Revision G (with Rev 5.0 EPROMs) upgrade. Even though it appears to be identical to the 9100FT Floppy drive wiring I am having trouble with drives run on the 9100A using the same disk drive as I am using on the 9100FT. Part of the problem comes because Fluke MODIFIED the floppy drives from stock. My Sony MP-F17W=L5 3-1/2" drive has some work done on the trace from pin 10 as well as a jumper from the Disk Loaded Switch (disk present switch - second one in - beside 1.44 switch) which is added to pin to pin 14. I have tried to copy this to a different Sony MP-17W-50C floppy but the boards are different, so without schematics (or pulling the board apart) it is difficult to figure out what is being changed. Thus, at the moment, I do NOT recommend upgrading your motherboard until I figure out (or someone else) what mods are needed to the floppies. As for is this a waste of time with emulators now available? There are any number of companies still running 9100s and they still have floppy backups and thus need to be able to read their disc and then convert to emulators. On a further note, the Canon MD360 (I think that is the number, not at shop) drive works on my 9100FT in both the regular Canon option as well as the Cannon (sic) HD option. When you enabled the HD option the drive asks you if you want to format in regular or high density mode. I do not have enough info on the MD360 to know if it was HD or not. I suspect not as I can't format anything to HD... John :-#)#
The Fluke (and whatever brand of floppy drive is installed into it) would never be involved in any such conversion.
Tony Jones via Techtoolslist
