Fluke 9100 Service Kit 818948?
Anyone ever run into this kit? According to the 9100 service manual it consists of: The Service Kit uses Guided Fault Isolation (GFI) programs to assist in troubleshooting 9100A/9105A systems. The Service Kit contains GFI and utility programs, an extender board, and instructions. John :-#)# -- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Hmm, seems I may actually have this kit here, in pieces. So far have found a pair of floppies labelled "9100A/AF UUT Test Disk V1.0" which may be the above mentioned disks for the Service Kit. I will archive that when I have a chance and post. Now to find the instructions as I am pretty sure I have at least one extender card in my stash of left over 9100 stuff! John :-#)# -- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist
I have several copies of this disk. I thought it had already been archived in the github archive but I just checked again and I don't see it. It's best if it gets dumped in Kryoflux stream format, same as all the other 9100 disks. There isn't much point having a few outliers stored on the ftp site in some other format. Curious on the extended board. Does it have a ZIF on it? I have a half dozen mystery extender boards with ZIFs on them. Obviously all of the above is handled totally differently on the FT version, per the sync connector on the mainboard.
Here is what I have. I have quite a few of them. https://drive.google.com/open?id=1HtPnQ4RHImthtOG3LdRTvR_2BGU-2QAG Based on reading the service manual it would make sense that it's designed to fit into one of the 9100A expansion slots and have a 68000 pod connect to it. The only time I've seen one for sale was on eBay where it was pictured in the listing for a 9900 pod (which also has a 64 pin probe head) so I assumed it was some weird 9900 AF test fixture. Possible mystery solved, I like this :)
Guess I needed to look closer, here it is: https://github.com/ieure/fluke-9100-disk-archive/tree/master/9100A-SYSTEM-4.... https://github.com/ieure/fluke-9100-disk-archive/blob/master/9100A-SYSTEM-4....
https://github.com/ieure/fluke-9100-disk-archive/blob/master/9100A-SYSTEM-4.... _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Yep, those seem to have shipped most or all 4.x 9100A disks. I have several copies, all identical, so omitted then from some disk sets I archived. It would be nice if someone found a later version for the FT. _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Supposedly part# 897116 but as I said in previous msg, you'll need a 9132FT along with a 9132FT sync module, 9132FT rom modules and a 9132FT-68030 personality module. The far more common 9132A-68030 personality module is marked in the 9100FT Emulation Selection Guide as unsupported for the 9132FT. _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
