Sencore CM2125 Monitor Analyzer
I'm curious if anyone is using one of these on their test bench? I managed to pick up a couple and have been playing around with them. I have some specific questions on the CGA advanced timing settings, like horizontal and vertical front and back porch timing settings. If anyone has one and has played with these setting, I'd like to know what has worked best for you on the old standard res monitors. Thanks James -- James Marous mailto:jmarous@woh.rr.com _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Thanks
James
James Marous
We've been using one of these for a few yearsm, great tool! Here are our settings: CGA: 15.8KHz-H, 640PIX-H, 60.5Hz-V, 200PIX-V EGA/Medium: 20.0KHz-H, 512PIX-H, 60Hz-V, 384PIX-V CGA looks a bit odd, I'd have figured 30Hz for Vert, and the 640X200PIX seems wrongish, however this is what Alex uses to test our customers monitors and he is very happy with the results. YMMV, TANSTAAFL! John :-#)# -- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
John, I am finding the same thing for CGA. The picture is stable, but there is keystoning and the raster is oddly shifted. After digging a little, I found that the default CGA settings stored in the 2125 (recall position 0) don't match the standard for CGA (http://www.arcade-museum.com/monitor.html). I think I'll try setting all of the timing parameters manually (page 16 of the 2125 manual) and see if that helps any. Thanks James -- James Marous mailto:jmarous@woh.rr.com -----Original Message----- From: John Robertson [mailto:jrr@flippers.com] Sent: Thursday, November 21, 2013 6:28 PM To: jmarous@woh.rr.com; Technical Tools Mail List Subject: Re: [Techtoolslist] Sencore CM2125 Monitor Analyzer On 11/21/2013 2:28 PM, James Marous wrote:
Thanks
James
James Marous
James Marous -
