Well with all the trouble going around trying to get a SCSI -> IDE for CF to work anyone know what the max size of SCSI drive will work in the 9100? There are a few on ebay and I need to replace the drive in my 9100. David _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
The 9100 will only see about 60mb. If you put in a larger drive it will see it as zero bytes, but this does not cause problems. I used a 100mb drive that showed as zero bytes for a few years. Andrew Welburn (mobile) www.andys-arcade.com On 1 Mar 2013, at 06:48, "David Shoemaker" <davids@oz.net> wrote:
Mine has a 300 MB SCSI drive installed. Op 1 mrt. 2013, om 08:26 heeft Andrew Welburn <andy@andysarcade.net> het volgende geschreven:
André Huijts andre.huijts@upcmail.nl _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Andre Huijts -
David Shoemaker
