ADDR ERROR @ XXXXh - LOOP?
And here is a new one for me, don't recall seeing that error message before, nor can I find reference to it in the 9010A Operator Manual. Pressing the MORE key gives me "ADDR BITS 0100 - LOOP?" so I assumed this was some sort of a decode issue and will proceed accordingly. Just thought I would post it here in case anyone else runs across this rare error message which I assume was added to the 3A ROMs in the 9010, but not to the manual - at least the copy I have... (later) It was indeed a problem with some address lines. For only A7 and A8 when loop reading @ 0000 (easiest - all should be Low) with the 9010 probe (set to Address) the Low light was flickering, not steady Low. Turned out to be a 74LS367 that had two inputs that were somehow pulling the lines slightly high. This did not show up when doing a ROM or BUSS test - only in either of the RAM tests. FYI John :-#)# -- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
FYI
Still later. Ran into this "ADDR ERROR @ 0000-LOOP? again, this time it was an Address line (A5) shorted to a Data line (D7). It doesn't matter which Data line the address line is shorted to, it gives the same message: Any Data line shorted to A0 gives/More ADDR BTS 0001-LOOP? Any Data line shorted to A1 gives/More ADDR BTS 0002-LOOP? Any Data line shorted to A2 gives/More ADDR BTS 0004-LOOP? Any Data line shorted to A3 gives/More ADDR BTS 0008-LOOP? Any Data line shorted to A4 gives/More ADDR BTS 0010-LOOP? ... Any Data line shorted to A15 gives/More ADDR BTS 8000-LOOP? FYI. John :-#)# -- John's Jukes Ltd. 7 - 3979 Marine Way, Burnaby, BC, Canada V5J 5E3 Call (604)872-5757 (Pinballs, Jukes, Video Games) flippers.com "Old pinballers never die, they just flip out" _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
I should mention this is a Fluke 9010A running with a 6800 pod - testing Bally MPU, which board being tested shouldn't matter though... On 2021/03/24 12:46 p.m., John Robertson via Techtoolslist wrote:
FYI
Still later.
FYI.
