Re: [Techtoolslist] Fluke 9105A
Well, it took me a bit. Did the battery add on for the RTC. Had to dig around to find a floppy drive that would work, but was able to use an older 386 machine with dos 6.22 to build some Service boot disks. Got the system booted and loaded the operating system. Set the time, and the system is so far working just fine. Waiting on some hardware to put a scsi2sd and will upgrade floppy drives as well. But so far so good. On Sun, Mar 7, 2021 at 12:54 AM Kevin Moore <talon.k@gmail.com> wrote:
Well, it took me a bit. Did the battery add on for the RTC. Had to dig around to find a floppy drive that would work, but was able to use and older 386 machine with dos 6.22 to build some Service boot disks. Got the system booted and loaded the operating system. Set the time, and the system is so far working just fine. Waiting on some hardware to put a scsi2sd and will upgrade floppy drives as well. But so far so good.
On Mon, Mar 1, 2021, 8:03 PM Tony Jones <tony@tonyjones.com> wrote:
On Mon, Mar 1, 2021 at 4:50 PM Kevin Moore <talon.k@gmail.com> wrote:
the RTC is dead,
Expose the battery terminals on the chip and solder on an aux battery cell (google; lots of threads on this). Or take your chances with Chinese replacement chips, _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Well, I got an SCSI2SD v 5.1 with a 16gb sd card. Built a service disk 1.4 and booted. I then did a system setup, noticed that under the 9105 there is no setting for the hard drive even after selecting that the system had a IEEE 488 card. So I did the 9100 setup, and there was a HDD setup. So I did that, and tested the SCSI2SD by running a format. Format ran fine. I then used the 6.1 img file Thank Andy wrote that to the SD card and rebooted. Bam. The system booted with the 6.1 img. Sweet!!! A few notes. The 9105a had v 5.0 roms, and 4 meg already installed. So that made things easier for me. Was also able to run the monitor display test on the service disk. The monitor works just fine! Woot. Next up is doing the mods for a standard AT keyboard. Being the nood that I am it took me a bit to understand the github file system, and never having used Samdisk was interesting for me. But atlot of reading I was able to get it figured out. The instructions I was able to find did seem to work with a bit of assumptions. It's definately not a step by step. But lot's of good work by those that helped build all the files and docs! I would thank all that were involved but I'm sure I would miss someone. But you all know who you are!! This will be a nice addition to my test equipment and it was cool learning about the scsi2sd and usb to floppy stuff. I did not know about those and that will help on other projects. Very cool stuff. Thank you all! Kevin On Sun, Mar 7, 2021, 11:08 AM Kevin Moore <talon.k@gmail.com> wrote:
the RTC is dead,
Kevin Moore
