I've got some extra stuff I don't need anymore. Perhaps someone can use it. Arium 4100 Logic Analyzer. Boots up, screen is bright, flickers a little (brightness pot dirty?). Comes with LP320 32 channel pod with lead set, 1/2 of the miniclips are still attached. $50. Hakko 484 desoldering iron. The collection tube (glass) and pull handle are cracked, but it heats up and pulls vacuum. This was my primary station until I got a larger one. Parts should still be available from Hakko direct. Comes with the box, manual/parts list, and cleaning tool. $35. Z80 probe for HP 1611 series logic analyzers. Untested, but was a working pull. I don't have a 1611 series to test on. $10. 6802 probe for Applied Microsystems logic analyzers. Untested. $10. Fluke Trendar 200 test clip. Put over a 16 or 14 pin IC in circuit, and it shows the LED status of all pins. Comes in case with manual, and some of the test clips. $20. Weller/Ungar 4624 solder/desoldering station. Both a pencil iron and a desoldering gun. Adjustable/regulated temp on both. Desoldering side could use a new tip, but it works okay as it is. Includes the cleaning pins. $50. _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist
Corey Stup
