Re: [Techtoolslist] Fluke 9010A and Space Invaders
Think 1, but thats an idea with the Z80 side of things.... --- John Robertson <jrr@flippers.com> wrote:
Hmm, I wonder if the SI boardset left out a ground that they thought wasn't needed by the CPU, but the Fluke is expecting...how many grounds does the 8080 want? Too lazy to look it up.
At 10:08 PM +0000 4/13/05, Martin White wrote:
Umm, go into the setup and disable the UUT Power Fail check??
I trust the power supply voltage isn't just too low down to the PSU or maybe voltage drop across an adapter?
Soory, very obvious points i know, but you gotta mention them :)
On Wednesday 13 April 2005 20:57, Phil Morris wrote:
Phil,. I've used the 8080 pod on the 2 board and it works fine.
I got that error once with one of the clock signals being bad by a broken trace.
Evidently, the pod check out all the powers and the clock signals going in for integrity.
But that's the thing - the boardset *does* work perfectly with a normal 8080 in the CPU socket.
I too was thinking of a clock signals problem, but they all check out okay.
Phil
_______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com
http://seven.pairlist.net/mailman/listinfo/techtoolslist
-- John's Jukes Ltd. 2343 Main St., Vancouver, BC, Canada V5T 3C9 Call (604)872-5757 or Fax 872-2010 (Pinballs, Jukes, VideoGames) www.flippers.com "Old pinballers never die, they just flip out" _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com
__________________________________ Do you Yahoo!? Yahoo! Small Business - Try our new resources site! http://smallbusiness.yahoo.com/resources/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist
Tony Gonzalez
