Fluke 9010a issue with pod self test
I just tried my new fluke 9010a with RS-232... passes self test... but when I plug a known working 6502 pod in and do a bus test it reports 6502 pod error 00 (iirc).... Is this a relatively easy fix or should I bite the bullet and move the rs-232 module over to my working unit ? ( Is that all I have to do ? or are there other modifications required to the base unit to accept it ?) I'd rather fix the faulty unit to be honest, as the worker is in really really great condition so I'd like to keep it as a spare and use the other new arrival for now..... Thanks for your help, Regards, Colin _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment
Having a look at the service manual I'm thinking it might need a new 6820 Pia chip... would I be along the right lines ? Cheers, Colin ----- Original Message ----- From: "Colin Davies" <colin.w.davies@btopenworld.com> To: <techtoolslist@flippers.com> Sent: Wednesday, September 24, 2008 1:18 AM Subject: [Techtoolslist] Fluke 9010a issue with pod self test
Ahh... I replaced the PIA with a 6821... still no joy... Then I noticed that the self test socket on the pod was a little loose (the thumb wheel is very very stiff on it) - Dohh !! Problem solved... a little embarrasing... :-) It was just my luck that when I swapped the pod over , it was making bad contact in the self test socket, swapped it to the working unit and contact was good...swapped back to faulty unit.. contact was bad... Finally put the pod back on the worker only to have it fail !! - That was a heart stopping moment... Then I noticed the cause !! This 9010a unit also only 3 roms, the manual mentions a piggy back rom board, but no sign of it... Running Version 3A ( I havent opened the other unit up, also 3A to check) Anyway... back to my first question.... Can you just swap the RS-232 module over without any further mods.. ? Thanks for you help guys.. Kind Regards, Colin ----- Original Message ----- From: "Colin Davies" <colin.w.davies@btopenworld.com> To: "Technical Tools Mail List" <techtoolslist@flippers.com> Sent: Wednesday, September 24, 2008 1:47 AM Subject: Re: [Techtoolslist] Fluke 9010a issue with pod self test
Cheers, Colin
I believe you can. The RS232 is an option that exists in address space if I remember correctly. It reads some status bits to know whether or not the RS232 is installed or not. On Wed, Sep 24, 2008 at 3:15 PM, Colin Davies <colin.w.davies@btopenworld.com> wrote:
Kind Regards, Colin
Cheers, Colin
-- -Adam "Please don't judge my God by my inability to follow him" - Chris Mollins =============== www.onecircuit.com www.youtube.com/user/ajcrm125 =============== _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment
Kind Regards, Colin
Hi Colin, Yes, you can move the RS-232 to the newer 9010. As for the ROM question, it depended on when the 9010 was made, some have the extension, others do not. However they are pretty much all -3A so the code is the same. John :-#)#
Cheers, Colin
-- John's Jukes Ltd. 2343 Main St., Vancouver, BC, Canada V5T 3C9 Call (604)872-5757 or Fax 872-2010 (Pinballs, Jukes, VideoGames) www.flippers.com "Old pinballers never die, they just flip out" _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment
Adam Courchesne -
Colin Davies -
