Can an HD74HC14 be used in place of a HD74LS14? Is it the same IC or is it different? Dan Piraino _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist
AFAIK, HC = High speed CMOS, LS = Low Power Schokkety (sp?) According to what i have read, you can use them interchangeably ONLY if all of the inputs and outputs are connected (which they probably are, but you'd need to check!). The ones that are properly compatible are the 74HCT14 as HCT = High speed Cmos with TTL compatible inputs and outputs (hence HCT). Best bet would be to try it, although if you're ordering in, i guess this is not the best route! Hope that helps, Martin. On Saturday 13 August 2005 03:37, Daniel Piraino wrote:
Daniel Piraino -
Martin White
