RE: [Techtoolslist] 6800 to 6502 pod combo ROM?
I am not sure there is a combo version? Here is the link to convert a 6800 to 6502 http://forums.arcade-museum.com/showthread.php?t=217476 -----Original Message----- From: techtoolslist-bounces@flippers.com [mailto:techtoolslist-bounces@flippers.com] On Behalf Of david grohowski Sent: Friday, November 08, 2013 11:18 AM To: jrr@flippers.com; techtoolslist@flippers.com Subject: [Techtoolslist] 6800 to 6502 pod combo ROM? Is this up for d/l anywhere? thx david grohowski electronicamuse@aol.com _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
As I recall the Fluke code is the same for the 6800 and 6502 pods, perhaps you just enable either the upper or lower half of the Eprom to select which pod the system thinks you have? Might be a project to make an adapter that converts back and forth... John :-#)# On 11/08/2013 10:49 AM, William Stillwell wrote:
thx
-- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Thje reason I assumed this, is this quote "If you decide to use the code with dual 6800 and 6502 in it you must take pin 19 and put it to +5v instead of ground. " and he says that he got the code from someone else, so.... I am not sure there is a combo version? Here is the link to convert a 6800 to 6502 http://forums.arcade-museum.com/showthread.php?t=217476 -----Original Message----- From: techtoolslist-bounces@flippers.com [mailto:techtoolslist-bounces@flippers.com] On Behalf Of david grohowski Sent: Friday, November 08, 2013 11:18 AM To: jrr@flippers.com; techtoolslist@flippers.com Subject: [Techtoolslist] 6800 to 6502 pod combo ROM? Is this up for d/l anywhere? thx david grohowski electronicamuse@aol.com _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
"If you decide to use the code with dual 6800 and 6502 in it you must take pin 19 and put it to +5v instead of ground."
The 6502 and 6800 code is in the same Eprom on file at the FTP site...look under Fluke/9010and9100Pods/6502pod or /6800pod - both have the same file for the Pod EPROM #540344 John :-#)#
thx
david grohowski -
