Re: [Techtoolslist] Directory success !!! (for HDR that is.)
I started for centipede once. I think I got all the ICs in but got bored after only a small amount of the connections. And I never really properly grasped the dividing up into functional blocks and scripting for those blocks properly. I found it hard to apply the examples to my case. Sorry for the lack of punctuation. In a bar, using my phone :) -----Original Message----- From: Andrew Welburn Sent: 12/12/2012 20:15 To: Technical Tools Mail List Subject: Re: [Techtoolslist] Directory success !!! (for HDR that is.) Because when you map a UUT (unit Under Test) netlist you need to tell it which part is in which location and how it is connected to every other IC on the PCB so that it can tell operators where to move in back-tracing a fault in GFI mode. (Guided Fault Isolation) Every device on the UUT needs describing, its I/O directions etc.. Fluke provides most TTL and basic discretes as you can see. The 9100 is very comprehensive, if you have the time to enter an entire PCBs worth of chips, and how each node is connected, then write exerciser programs that cover every functional block (every IC) of the PCB, the 9100 will guide you to a fault 100% accurately. However, the man-hours involved in entering all that information, and writing programs that exercise every chip on the PCB is way beyond 95% of people. Its totally uneconomical to do this for any arcade game PCB, as every game PCB is completely different The GFI mode was intended more for production or high volume stuff. An engineer would spend a few months writing/entering all the info for *one single UUT* on a 9100A for example with an editing suite, then the program could be run on a 9105 or a 9100A without any editing suite. The target user would be a production operator who could let the 9100 guide them to the fault by instructing them to clip and probe here and there and provide fault analysis. In UFI mode, you write programs specifically for one or many UUT's, but the programs can be launched by whomever, whenever. This is how i use the 9100, with my own custom programs, launched from the operators keypad or from my own menu system (video display) Or you can use it in operator mode, much like the functionality of a 9010, but you are restricted to keypad functionality unless you have written programs that you can call up in stored UUT's. A good read of the manuals (lengthy reading) will teach you what the system is capable of, which is - everything. Providing you put in the man hours to cover a pcb, the 9100 will fault find for you, you need only follow its on-display instructions and it will isolate a fault for you. I dont think anybody is crazy enough to do that however :) Andrew Welburn http://www.andys-arcade.com On 11/12/2012 21:27, David Shoemaker wrote:
I am really curious about the PARTLIB directory and what that is all about. Why are there TTL chips and connectors on the 9100?
-----Original Message----- From: techtoolslist-bounces@flippers.com [mailto:techtoolslist-bounces@flippers.com] On Behalf Of Andre Huijts Sent: Monday, December 10, 2012 1:44 PM To: Technical Tools Mail List Subject: [Techtoolslist] Directory success !!! (for HDR that is…)
Thanks to Martin's instruction file about setting up RS-232 comms between a PC and the 9100 AND one of his e-mails about the backup utility I succeeded in getting a directory from the HD in the 9100.....
I remembered that I still had one of those blue "Laplink" cables, very nice null-modem cable with on one end a sub-9 D and on the other both a sub-9 and a sub-25 (?) So that fitted perfectly. I used my ancient Toshiba T1910 that I recently dug-out to set-up my Needham EMP-10 EPROM programmer. I searched a bit for a DOS terminal program and I found CONEX75.
I was typing messages from and to the 9100 right away ! :)
Following the instructions about the Backup utility (which turned out to be already installed) and using the "capture to file" option I succeeded in getting a complete directory.
I could have used my USB to RS-232 cable and the Mac just as well of course but this was only to see if I got it to work at all...
Reading further in the PDF I saw that it is not possible to just get a directory from a floppy. (The only directory you can get from a floppy is from a backup set, using the last disk of the set)
Moved the file using "sneaker net" to the Mac and now I am going to bore you guys with the entire directory ! :)
If there is anything wrong (that I should remove) or interesting down here....please let me know :)
Contents of directory /HDR/ Filename Size Write Protected Date Time ====================== ========= =============== =============== Info 47 Protected 09/11/26 21:25 MEVALID 0 Protected 93/10/19 17:12 NDISKS 2 Protected 91/07/24 14:48 TEXT$BACKUP.DIR 0 09/12/09 22:54 ZYSETIOMOD 944 Protected 90/07/19 14:29 ZYSETKYSEQ 1120 Protected 90/07/19 14:29 ZYSETMISC 116 Protected 90/07/19 14:29 ZYSETPOD 628 Protected 90/07/19 14:29 ZYSETRAMRO 24 Protected 90/07/19 14:29
Contents of directory /HDR/HELPLIB$HELPLIB/ Filename Size Write Protected Date Time ====================== ========= =============== =============== INFO 40 91/04/01 15:54 TEXT$BUS1 545 91/03/29 15:37 TEXT$BUS2 538 91/03/29 15:37 TEXT$BUS3 534 91/03/29 15:37 TEXT$BUS4 537 91/03/29 15:37 TEXT$BUS5 537 91/03/29 15:37 TEXT$BUS6 653 91/03/29 15:37 TEXT$CLKMOD1 103 91/03/29 15:37 TEXT$GEN1 157 91/03/29 15:38 TEXT$INDEX 1374 91/03/29 15:38 TEXT$IOMOD1 80 91/03/29 15:38 TEXT$IOMOD2 253 91/03/29 15:38 TEXT$IOMOD3 101 91/03/29 15:38 TEXT$MPOD1 311 91/03/29 15:38 TEXT$MPOD10 250 91/03/29 15:38 TEXT$MPOD2 309 91/03/29 15:38 TEXT$MPOD3 421 91/03/29 15:38 TEXT$MPOD4 372 91/03/29 15:38 TEXT$MPOD5 224 91/03/29 15:38 TEXT$MPOD6 393 91/03/29 15:38 TEXT$MPOD7 385 91/03/29 15:38 TEXT$MPOD8 269 91/03/29 15:38 TEXT$MPOD9 475 91/03/29 15:38 TEXT$POD1 120 91/03/29 15:38 TEXT$POD10 172 91/03/29 15:38 TEXT$POD11 123 91/03/29 15:38 TEXT$POD12 159 91/03/29 15:38 TEXT$POD13 356 91/03/29 15:38 TEXT$POD14 519 91/03/29 15:38 TEXT$POD15 145 91/03/29 15:38 TEXT$POD16 215 91/03/29 15:38 TEXT$POD2 440 91/03/29 15:38 TEXT$POD3 175 91/03/29 15:38 TEXT$POD4 437 91/03/29 15:38 TEXT$POD5 623 91/03/29 15:38 TEXT$POD6 522 91/03/29 15:38 TEXT$POD7 184 91/03/29 15:38 TEXT$POD8 523 91/03/29 15:38 TEXT$POD9 395 91/03/29 15:38 TEXT$PROBE1 96 91/03/29 15:38 TEXT$RAM1 538 91/03/29 15:38 TEXT$RAM10 343 91/03/29 15:38 TEXT$RAM11 216 91/03/29 15:38 TEXT$RAM12 261 91/03/29 15:38 TEXT$RAM13 530 91/03/29 15:38 TEXT$RAM2 585 91/03/29 15:38 TEXT$RAM3 592 91/03/29 15:38 TEXT$RAM4 387 91/03/29 15:38 TEXT$RAM5 387 91/03/29 15:38 TEXT$RAM6 226 91/03/29 15:38 TEXT$RAM7 714 91/03/29 15:38 TEXT$RAM8 159 91/03/29 15:38 TEXT$RAM9 161 91/03/29 15:38 TEXT$ROM1 413 91/03/29 15:38 TEXT$ROM2 397 91/03/29 15:38 TEXT$ROM3 217 91/03/29 15:38 TEXT$ROM4 218 91/03/29 15:38 TEXT$ROM5 254 91/03/29 15:38 TEXT$ROM6 303 91/03/29 15:38 TEXT$ROM7 338 91/03/29 15:38 TEXT$UNKNOWN1 133 91/03/29 15:38
Contents of directory /HDR/OPTIONS/ Filename Size Write Protected Date Time ====================== ========= =============== ===============
Contents of directory /HDR/OPTIONS/EDITOR/ Filename Size Write Protected Date Time ====================== ========= =============== =============== OPTION_NAME 19 Protected 91/07/24 14:47
Contents of directory /HDR/OPTIONS/EDITOR/ROM/ Filename Size Write Protected Date Time ====================== ========= =============== =============== COMPATEDITOR 102 Protected 91/07/24 14:45 CONFIGEDITOR 140 Protected 91/07/24 14:45 MEGMAX 276644 Protected 91/07/24 14:39
Contents of directory /HDR/PARTLIB$PARTLIB/ Filename Size Write Protected Date Time ====================== ========= =============== =============== PART$146818SP 404 91/03/29 15:39 PART$1797 187 91/03/29 15:39 PART$2016 423 91/03/29 15:39 PART$2444 43 91/03/29 15:39 PART$2531 53 91/03/29 15:39 PART$2674 1385 91/03/29 15:39 PART$2675 498 91/03/29 15:39 PART$2681 1283 91/03/29 15:39 PART$27128 512 91/03/29 15:39 PART$27256 488 91/03/29 15:39 PART$28S42 332 91/03/29 15:39 PART$4000 109 91/03/29 15:39 PART$41128 109 91/03/29 15:39 PART$4164 107 91/03/29 15:39 PART$4256 131 91/03/29 15:39 PART$68000 433 91/03/29 15:39 PART$7400 90 91/03/29 15:39 PART$7401 89 91/03/29 15:39 PART$7402 89 91/03/29 15:39 PART$7403 90 91/03/29 15:39 PART$7404 87 91/03/29 15:39 PART$7405 87 91/03/29 15:39 PART$7406 87 91/03/29 15:39 PART$7407 87 91/03/29 15:39 PART$7408 90 91/03/29 15:39 PART$7409 90 91/03/29 15:39 PART$7410 91 91/03/29 15:39 PART$74107 111 91/03/29 15:39 PART$74109 129 91/03/29 15:39 PART$7411 91 91/03/29 15:39 PART$74111 129 91/03/29 15:39 PART$74112 131 91/03/29 15:40 PART$74113 111 91/03/29 15:40 PART$74114 121 91/03/29 15:40 PART$7412 91 91/03/29 15:40 PART$74121 97 91/03/29 15:40 PART$74122 127 91/03/29 15:40 PART$74123 105 91/03/29 15:40 PART$74125 90 91/03/29 15:40 PART$74126 90 91/03/29 15:40 PART$74128 89 91/03/29 15:40 PART$7413 88 91/03/29 15:40 PART$74131 179 91/03/29 15:40 PART$74132 90 91/03/29 15:40 PART$74133 109 91/03/29 15:40 PART$74134 109 91/03/29 15:40 PART$74138 179 91/03/29 15:40 PART$74139 143 91/03/29 15:40 PART$7414 87 91/03/29 15:40 PART$74148 209 91/03/29 15:40 PART$7415 91 91/03/29 15:40 PART$74150 164 91/03/29 15:40 PART$74151 142 91/03/29 15:40 PART$74153 112 91/03/29 15:40 PART$74157 119 91/03/29 15:40 PART$74158 119 91/03/29 15:40 PART$7416 87 91/03/29 15:40 PART$74160 175 91/03/29 15:40 PART$74161 175 91/03/29 15:40 PART$74162 175 91/03/29 15:40 PART$74163 175 91/03/29 15:40 PART$74164 139 91/03/29 15:40 PART$74165 142 91/03/29 15:40 PART$74166 109 91/03/29 15:40 PART$7417 87 91/03/29 15:40 PART$74174 120 91/03/29 15:40 PART$74175 135 91/03/29 15:40 PART$7420 88 91/03/29 15:40 PART$7421 88 91/03/29 15:40 PART$7422 88 91/03/29 15:40 PART$7423 107 91/03/29 15:40 PART$7424 90 91/03/29 15:40 PART$74240 139 91/03/29 15:40 PART$74241 139 91/03/29 15:40 PART$74244 139 91/03/29 15:40 PART$74245 227 91/03/29 15:40 PART$7425 93 91/03/29 15:40 PART$74253 112 91/03/29 15:40 PART$74257 119 91/03/29 15:40 PART$7426 90 91/03/29 15:40 PART$74260 93 91/03/29 15:40 PART$7427 91 91/03/29 15:40 PART$74273 159 91/03/29 15:40 PART$7428 89 91/03/29 15:40 PART$74280 118 91/03/29 15:40 PART$74288 227 91/03/29 15:40 PART$7430 86 91/03/29 15:40 PART$7431 101 91/03/29 15:40 PART$7432 90 91/03/29 15:40 PART$7433 89 91/03/29 15:40 PART$7434 87 91/03/29 15:40 PART$7435 87 91/03/29 15:40 PART$7437 90 91/03/29 15:40 PART$74373 159 91/03/29 15:40 PART$74374 159 91/03/29 15:40 PART$7438 90 91/03/29 15:40 PART$74390 123 91/03/29 15:40 PART$7446 193 91/03/29 15:40 PART$7447 193 91/03/29 15:40 PART$7448 193 91/03/29 15:40 PART$7451 87 91/03/29 15:40 PART$74521 136 91/03/29 15:40 PART$74543 292 91/03/29 15:40 PART$74573 155 91/03/29 15:40 PART$74590 219 91/03/29 15:40 PART$74612 1584 91/03/29 15:40 PART$7464 95 91/03/29 15:40 PART$74646 405 91/03/29 15:41 PART$74657A 161 91/03/29 15:41 PART$7472 118 91/03/29 15:41 PART$7473 107 91/03/29 15:41 PART$7474 111 91/03/29 15:41 PART$7475 119 91/03/29 15:41 PART$7476 123 91/03/29 15:41 PART$74760 139 91/03/29 15:41 PART$7486 90 91/03/29 15:41 PART$7490 112 91/03/29 15:41 PART$7492 96 91/03/29 15:41 PART$7493
[The entire original message is not included.] _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
and another one comes through that was a reply to my reply that had the full directory quoted below! hehhehe (I trimmed it this time!) Andrew Welburn http://www.andys-arcade.com On 12/12/2012 20:34, Martin White wrote:
[snip!] _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Funny, I was thinking about using Centi as well.....reasons were because I own one, it's a raster game (seemed simpler than a vector game to me) and Atari already makes the schematics in "functional blocks"...... Been trying to read in the Applications manual today (during work breaks....) and I nodded off at least 10 times....apart from that, it's sure not easy.... However.....correct me if I'm wrong, but I think the majority of problems can be found using the very "basic" tests (which are actually pretty thorough) being the address and databusses, finding bad buffers and doing RAM and ROM checks. As such it's not much more than a 9010 I guess, which is a bit of a shame of course, but I don't see anyone investing so many hours to get programs done for himself or maybe a couple of other guys interested..... It would be cool to have a program for POKEY (if only to make it produce some sounds ;) ) f.i., on the other hand, swapping one takes just seconds and most of the signals of it being defective are pretty well known.... Someone should write a program that scans the schematics of any PCB and turns it into a TL/1 program ;) André Op 12 dec. 2012, om 21:34 heeft Martin White <martin@guddler.co.uk> het volgende geschreven:
André Huijts andre.huijts@upcmail.nl _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Andre.. You havn't read all the manuals, and dont fully grasp what the 9100 can do. Its much, much more than a 9010, its a complete 100% pcb test system, as i've previously described, its not limited to rams and roms. Read up and learn my young jedi. Andrew Welburn http://www.andys-arcade.com On 13/12/2012 16:45, Andre Huijts wrote:
André
Hush ! I'm reading ! Op 13 dec. 2012, om 17:50 heeft Andrew Welburn <andy@andysarcade.net> het volgende geschreven:
Andre..
André
Andrew....I'm not stupid. I understand what it can do for about 90% by now, I've read enough to have a pretty clear picture. However, without any programs that actually DO a 100% test it's not really worth anything right ? Please stop talking down to me Andrew, I'm not a moron..... Op 13 dec. 2012, om 17:50 heeft Andrew Welburn <andy@andysarcade.net> het volgende geschreven:
Andre..
André
Hey, Andre, Andrew is just pulling your leg! The 9100 can be a bit of a boat anchor/door stop unless you really get into it. They are still in wide use industrially as they are often the only machine keeping production line equipment running that was designed in the 80s and 90s. Even the basic tests are superior to the 9010 though as you can easily store the results and easily make lookup tables for individual games if you have the programming option. I've found the renewed interest in the 9100 (thanks in large part to Andre) to be refreshing my desire to get this great tool in use in my shop - for too many years have they been sitting on a shelf being ignored. I mostly use the 9010 and my collection of pods to troubleshoot, and while that is fine for me, it would benefit my staff if I got a 9100 running with the tests built in for are common game board (Atari, Bally, Williams, etc.) that come through on a regular basis and while the test fixture gives us a pretty good idea of the problems, integrating a 9100 could speed up the tests significantly. The beauty of the 9100 is the GFI. I see building tests for Capcom and other orphans of the pinball world where no test fixtures exist or are more money than one cares to spend when you only see the game once every few years - however a guided test for the driver board, shared with this group, could help a number of shops deal with these games quickly. Making up a Bed Of Nails test jig that is hooked to the 9100 seems to be a good project for 2013 and I for one will be exploring this project in the new year. Have to get past Xams first - we are very busy right now! Still also hoping to find a non-serialized copy of 6.0 Service (was included in the 40MB SCSI upgrade kit) - or even a copy that has a different serial number to compare. Another project is to check the wiring changes to the motherboards - I suspect the latest ones (I have a "G" revision) allow you to use the 1.44 floppies, a number of jumpers around the floppy connector... John :-#)#
Andre..
André
-- John's Jukes Ltd. 2343 Main St., Vancouver, BC, Canada V5T 3C9 Call (604)872-5757 or Fax 872-2010 (Pinballs, Jukes, VideoGames) www.flippers.com "Old pinballers never die, they just flip out" _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
There's a Teledisk image of a service disk, as well as a bunch of other documentation, over here: http://www.iobium.com/9100a%20tester/ Not sure whether this one is serialized or not. --David On Thu, Dec 13, 2012 at 2:09 PM, John Robertson <jrr@flippers.com> wrote:
Andre..
André
--David
That's Martin Reynolds site - another TTL past regular...(are you still around Martin?) http://www.iobium.com/9100a%20tester/9100atester.htm Interesting that he talks about Service disk 6.0...I will take another look at the file Service.TD0 on his site, thanks! John :-#)#
Andre..
André
John, I found one disk with a hand written label Service disk V6.0 I just made a Samdisk image of it and attached it to this mail not sure if that works or not....I also don't know if it's serialized or not .... At least you will have 3 disks/images to look at. Op 13 dec. 2012, om 21:16 heeft John Robertson <jrr@flippers.com> het volgende geschreven:
--David
Andre..
André
Hi Andre, I'll check it out over the weekend, have permitted it out into the wilds of TTL mail list as well. Lets hope it is not another copy of the original one from TTL! Thanks! John :-#)# Andre Huijts wrote:
John,
--David
Andre..
> Funny, I was thinking about using Centi as well.....reasons were because > I own one, it's a raster game (seemed simpler than a vector game to me) and > Atari already makes the schematics in "functional blocks"...... > > Been trying to read in the Applications manual today (during work > breaks....) and I nodded off at least 10 times....apart from that, it's sure > not easy.... > > However.....correct me if I'm wrong, but I think the majority of > problems can be found using the very "basic" tests (which are actually > pretty thorough) being the address and databusses, finding bad buffers and > doing RAM and ROM checks. As such it's not much more than a 9010 I guess, > which is a bit of a shame of course, but I don't see anyone investing so > many hours to get programs done for himself or maybe a couple of other guys > interested..... > > It would be cool to have a program for POKEY (if only to make it produce > some sounds ;) ) f.i., on the other hand, swapping one takes just seconds > and most of the signals of it being defective are pretty well known.... > > Someone should write a program that scans the schematics of any PCB and > turns it into a TL/1 program ;) > > André > > >
Andre Huijts wrote:
John,
Being the really patient guy I am I decided to test this disk over lunch...I get the same error (disk is serialized). Have you tried this 6.0 disk in your machine? If it works, what is the serial number of your 9100? Currently converting the floppy image to a TD0 file so I can run Hexedit comparison on it. Nuts, I need a DOS computer to do that...my XP machine won't recognize C: (FAT64 I guess). John :-#)#
--David
Andre..
No luck, says "Fluke 9100A Service Init Disk. v6.0 This Board Has An Invalid Service ID" :( BUT, maybe this was used on the 9105 that I sold to Andrew so maybe he can have a look and post the serial number of that machine.... Op 14 dec. 2012, om 00:14 heeft John Robertson <jrr@flippers.com> het volgende geschreven:
Andre Huijts wrote:
John,
--David
> Andre.. > > You havn't read all the manuals, and dont fully grasp what the 9100 can > do. Its much, much more than a 9010, its a complete 100% pcb test system, as > i've previously described, its not limited to rams and roms. Read up and > learn my young jedi. > > > Andrew Welburn > http://www.andys-arcade.com > > On 13/12/2012 16:45, Andre Huijts wrote: > > >> Funny, I was thinking about using Centi as well.....reasons were because >> I own one, it's a raster game (seemed simpler than a vector game to me) and >> Atari already makes the schematics in "functional blocks"...... >> >> Been trying to read in the Applications manual today (during work >> breaks....) and I nodded off at least 10 times....apart from that, it's sure >> not easy.... >> >> However.....correct me if I'm wrong, but I think the majority of >> problems can be found using the very "basic" tests (which are actually >> pretty thorough) being the address and databusses, finding bad buffers and >> doing RAM and ROM checks. As such it's not much more than a 9010 I guess, >> which is a bit of a shame of course, but I don't see anyone investing so >> many hours to get programs done for himself or maybe a couple of other guys >> interested..... >> >> It would be cool to have a program for POKEY (if only to make it produce >> some sounds ;) ) f.i., on the other hand, swapping one takes just seconds >> and most of the signals of it being defective are pretty well known.... >> >> Someone should write a program that scans the schematics of any PCB and >> turns it into a TL/1 program ;) >> >> André >> >>
Has anyone found two matching disks with different serial numbers? It shouldn't be that hard to figure out where on the disk it is stored. Unless they used it as a hash key for the entire contents of course :) David -----Original Message----- From: techtoolslist-bounces@flippers.com [mailto:techtoolslist-bounces@flippers.com] On Behalf Of Andre Huijts Sent: Friday, December 14, 2012 9:13 AM To: jrr@flippers.com; Technical Tools Mail List Subject: Re: [Techtoolslist] Directory success !!! (for HDR that is.) No luck, says "Fluke 9100A Service Init Disk. v6.0 This Board Has An Invalid Service ID" :( BUT, maybe this was used on the 9105 that I sold to Andrew so maybe he can have a look and post the serial number of that machine.... Op 14 dec. 2012, om 00:14 heeft John Robertson <jrr@flippers.com> het volgende geschreven:
Andre Huijts wrote:
John,
--David
> Andre.. > > You havn't read all the manuals, and dont fully grasp what the > 9100 can do. Its much, much more than a 9010, its a complete > 100% pcb test system, as i've previously described, its not > limited to rams and roms. Read up and learn my young jedi. > > > Andrew Welburn > http://www.andys-arcade.com > > On 13/12/2012 16:45, Andre Huijts wrote: > > >> Funny, I was thinking about using Centi as well.....reasons >> were because I own one, it's a raster game (seemed simpler than >> a vector game to me) and Atari already makes the schematics in "functional blocks"...... >> >> Been trying to read in the Applications manual today (during >> work >> breaks....) and I nodded off at least 10 times....apart from >> that, it's sure not easy.... >> >> However.....correct me if I'm wrong, but I think the majority >> of problems can be found using the very "basic" tests (which >> are actually pretty thorough) being the address and databusses, >> finding bad buffers and doing RAM and ROM checks. As such it's >> not much more than a 9010 I guess, which is a bit of a shame of >> course, but I don't see anyone investing so many hours to get >> programs done for himself or maybe a couple of other guys interested..... >> >> It would be cool to have a program for POKEY (if only to make >> it produce some sounds ;) ) f.i., on the other hand, swapping >> one takes just seconds and most of the signals of it being defective are pretty well known.... >> >> Someone should write a program that scans the schematics of any >> PCB and turns it into a TL/1 program ;) >> >> André >> >>
Pretty sure John is working on that... Op 15 dec. 2012, om 00:01 heeft David Shoemaker <davids@oz.net> het volgende geschreven:
Andre Huijts wrote:
John,
--David
Andre Huijts wrote:
> Andrew....I'm not stupid. I understand what it can do for about > 90% by now, I've read enough to have a pretty clear picture. > > However, without any programs that actually DO a 100% test it's > not really worth anything right ? > > Please stop talking down to me Andrew, I'm not a moron..... > > > Hey, Andre, Andrew is just pulling your leg!
> Op 13 dec. 2012, om 17:50 heeft Andrew Welburn > <andy@andysarcade.net> het volgende geschreven: > > > >> Andre.. >> >> You havn't read all the manuals, and dont fully grasp what the >> 9100 can do. Its much, much more than a 9010, its a complete >> 100% pcb test system, as i've previously described, its not >> limited to rams and roms. Read up and learn my young jedi. >> >> >> Andrew Welburn >> http://www.andys-arcade.com >> >> On 13/12/2012 16:45, Andre Huijts wrote: >> >> >>> Funny, I was thinking about using Centi as well.....reasons >>> were because I own one, it's a raster game (seemed simpler than >>> a vector game to me) and Atari already makes the schematics in "functional blocks"...... >>> >>> Been trying to read in the Applications manual today (during >>> work >>> breaks....) and I nodded off at least 10 times....apart from >>> that, it's sure not easy.... >>> >>> However.....correct me if I'm wrong, but I think the majority >>> of problems can be found using the very "basic" tests (which >>> are actually pretty thorough) being the address and databusses, >>> finding bad buffers and doing RAM and ROM checks. As such it's >>> not much more than a 9010 I guess, which is a bit of a shame of >>> course, but I don't see anyone investing so many hours to get >>> programs done for himself or maybe a couple of other guys interested..... >>> >>> It would be cool to have a program for POKEY (if only to make >>> it produce some sounds ;) ) f.i., on the other hand, swapping >>> one takes just seconds and most of the signals of it being defective are pretty well known.... >>> >>> Someone should write a program that scans the schematics of any >>> PCB and turns it into a TL/1 program ;) >>> >>> André >>> >>>
Andre Huijts -
David Ryskalczyk -
Martin White
