Re: [Techtoolslist] replacing flat cables/connectors
I'm not so sure - there is something going on in the 40-pin DIP header on those cables as they have different numbers depending on the POD. I suspect grounds are what is varied, but never tested that supposition...
http://flippers.com/fluke.html <http://flippers.com/fluke.html>
Note the different part numbers for the UUT cables at the bottom of the page...
John :-#(#
John- I had a 6502 pod with the flat cable, and successfully replaced it using a section of flat cable I cut to length, and using the connector noted by Tony. The only downside is that instead of having the cable come in the top/middle of the connector, it comes in the side, which makes it a bit tricky for some applications, but I’ve had zero issues beyond that otherwise. Regards, Brent _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
I have a new one, still sealed on the blister display card, model LM-2A. Any interest, offers? This is the one that you clip over an IC on a live board and it has 16 LEDs that light up to indicate the state of each pin. Art ----- _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Art -
sprout.the@gmail.com
