Has anyone got a teledisk image of the fluke 9100 service disk? Or any other way of testing and formatting a 9100a hard disc? My NOS 9100a is failing to boot from the HDD (first time ever!), when it boots from floppies and I attempt to copy files from the system floppies to the HDD results in error : I/O Module fuse blown! This seems unlikely since there is no IO module or anything else for that matter plugged in. I swapped in the noisey HDD from my other system and the machine boots just fine. I tried swapping the MFM-SCSI adaptor card but that made no difference so it's either a drive fault or it needs a reformat. Thanks for any help, Steve _______________________________________________________________________ Freeserve AnyTime, only £13.99 per month with one month's FREE trial! For more information visit http://www.freeserve.com/time/ or call free on 0800 970 8890
Urk....sounds like bad hard drive. I am trying to figure a work-around for this,but am too busy with the Xmas season to deal with it right now. A couple of us are trying to adapt larger SCSI drives. The rev 4 service disk will format the old 20 MB MFM Micropolis drives, and I think I have found a source of some good used ones, but I just haven't had a chance to pick them up. Hope to do that in January and then I might have some spares. If you ask some older techies, they might have these drives kicking around. I am also going to experiment with some early MAC SCSI drives - they are 20 MB as well... John :-#)# At 02:14 PM 14/12/2002 +0000, steve@coule.freeserve.co.uk wrote:
Steve
The rev 4 service disk will format the old 20 MB MFM Micropolis drives, and I think I have found a source of some good used ones, but I just haven't had a chance to pick them up. Hope to do that in January and then I might have some spares. If you ask some older techies, they might have these drives kicking around. I am also going to experiment with some early MAC SCSI drives - they are 20 MB as well... The revision 4 software won't be able to format or control a standard SCSI drive, including those MACs. Its all setup to only understand how to operate the WD1006 and Adaptec 4000/5000 boards, neither of which are "standard" SCSI.
We all just need to buy SCSI drives with the V6 upgrade from Shy. Screw these MFM drives.
Corey Stup -
