Re: [Techtoolslist] replacing flat cables/connectors
On May 18, 2016 5:16 AM, <sprout.the@gmail.com> wrote:
I had a 6502 pod with the flat cable, and successfully replaced it using a section of flat cable I cut to length, and using the connector noted by Tony. The only downside is that instead of having the cable come in the top/middle of the connector, it comes in the side, which makes it a bit tricky for some applications, but I’ve had zero issues beyond that otherwise.
Hi Brent. Thanks for this. Have you ever seen a 64 pin version of these connectors? Several companies seem to make a 40 pin "dip plug" (as they seem to be called) but I've had no luck locating a 64 pin version. best Tony _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
