Fluke clock module.
I second that. I have a 9010a with the clock module installed and a pod that John lent me. I'd love to know how to use it. Plus I have the tape binaries (I think). I just don't know how to use the darn thing. Matt _____________________________________________________________________ On Tue, 7 May 2002, Kev wrote:
Philip,
Could you scan or make copies available for scanning of the info you have? I'm not aware of it being available on the ftp or spies.
Thanks, Kev mowerman@erols.com
----- Original Message ----- From: Philip Mayor To: TechToolsList@flippers.com Sent: Tuesday, May 07, 2002 9:09 AM Subject: Fluke clock module.
It was known as the asynchronous signature probe option and consisted of a special pcb installed in 9010 mainframe with an extra d-sub connector on the front, the actual clock module, and a set of special operating programs on a tape. There are five probes coming from the clock module, they are: start, stop, clock, enable and ground.
Philip: I have original fluke info on this option if you need it.
Thanks, Phil.
I would expect that the Fluke keyboard uses a standard 8048 processor, and these can be read in some Eprom programmers (I have that ability with my Xeltek)
So, does anyone have a keyboard that also has a facility to read the 8048? It would be a good idea to back it up if nothing else, but I really suspect these are just modified IBM 101 PC keyboards (not the AT has to have the active RESET line in the cable)
I have both the keyboard and the ability to read the 8048s. I'll see what my timeline is later this evening.
I opened my Fluke Programmer's keyboard for the 9100A this evening. I'll have you guys know I just voided my warranty doing so! (had to break a seal...) Anyway, it has a few interesting things. The board is denoted with a patent: 4,420,744. The main controller has the following markings on it: Z (appears to be the Zilog logo) SR0131 2-8756-819 8614
Hi Corey, Check the pinout of your keyboard encoder with this site: http://www.xs4all.nl/~ganswijk/chipdir/giicm/8048.txt I bet the Xtal is on pins 1 & 2, plus the +5 and Gnd will also be correct....also that the RESET pin on the plug (center pin of the five) goes directly to pin 4 on the IC...if not then check the 8051... http://www.xs4all.nl/~ganswijk/chipdir/giicm/8051.txt Almost every keyboard that I have seen since the old Apple II's has used a 8048, 8051, or variation of same. John :-#)# At 11:41 PM 08/05/2002 -0400, Corey Stup wrote:
Corey, I'll take a guess that you are correct it is a Zilog, Judging by the info on this page.... http://govschl.ndsu.nodak.edu/~achapwes/PICmicro/keyboard/atkeyboard.html I belive the chip is a 8614 Keyboard Encoder. Now can we copy it? I'm looking at .... www.zilog.com/docs/pc/z8602_ap.pdf now Thanks, Kev
Corey,
Now can we copy it?
The main controller is soldered onto the board. I'm not going to take a chance ruining it to make a copy. I will remove the board and trace down what actual chip it is. The crystal does not appear to go to the same pins as a 8048.
I can understand that.
I'm confident it is a Zilog controller. I cann't find a datasheet on the 8614 but a replacement/upgrade http://www.zilog.com/docs/pc/z86e23_ds.pdf That is compatible has a security mode that prevents reading the onboard ROM. Otherwise it is configured to read as a standard 2764 EPROM. Now if that is true of the 8614 & you had a 40 pin dip clip & a ROM download program for your 9100...... Thanks, Kev
8614 Datasheet http://www.freetradezone.com/design_center/images/pdf/D0165129.pdf It appears to be a MASKED ROM but I cann't understand if they are trying to say it is program configurable via the PC or just the ROM? It would be interesting to note what is tied to which pin & if it is wired for AT or XT style. Kev
How would I identify a 9100 Keyboard if one were to appear? Is there a model number or some other readily identifiable markings? I assume that a 1720 controller or other Fluke items don't use compatable keyboards? Thanks, Kev
Browsing thru the 9100 service manual. The 9100 Keyboard is TTL level Serial ASCII @ 1200 BAUD 1 Start Bit 8 Data Bits (LSB->MSB) 2 STOP BITS (AT Keyboards do 1/8/1parity/1stop) RESET is sent from the CPU to the Keyboard. Does a RESET cause a keyboard response? Thanks, Kev
And remember, an AT keyboard is nowhere near 1200 baud. And the AT keyboard not only tells you when a key is pressed, it also tells you when it is released. It's starting to sound like the 9100 keyboard just sends simple text as it's typed. If that is what it is REALLY doing this should be very simple. (Uh, what are we trying to do again?) Kev wrote:
Thanks, Kev
OBJECTIVE: Replace missing 9100 Programmer Keyboard. Unfortunately Hyperterminal doesn't have a start bit otherwise I could try the theory.... Awful convoluted to use a PC in terminal mode just for a keyboard for the 9100 but I'll take it at the moment! Thanks, Kev
As for a potentially nice Serial interface I'm experimenting with Zterm from: http://www.coolstf.com/ looks nice and is very configurable... Do you have any idea of the data stream the keyboard needs? You need a start bit? I thought most serial communications used a single start bit when in 7 bit mode. John :-#)# At 01:56 PM 09/05/2002 -0400, Kev wrote:
Thanks, Kev
Has anyone developed a way to deal with Security CPUs/ Non Standard CPUs on boards when using a Fluke Microprocessor tester? Burgertime is my current challenge. Crazy climber also comes to mind. Any & all suggestions appreciated. Thanks, Kev
All you can do is to make an adapter for the CPU edge connector, I believe that the one on Burgertime is the same as others that Bally used. You would need a card edge connector wired to a 40pin ribbon cable with a 40 pin dip plug/socket for the pod to connect to. I am going to make one up for the Z80's as used in Pacman and see how it works when I get better. John :-#)# At 08:44 AM 15/05/2002 -0400, Kev wrote:
Thanks, Kev
Is anyone scanning the 9010A Async manuals? I've got both the op & services manuals here to scan but didn't want to duplicate anyone elses efforts. After that I hope to scan the Z80QT manual & perhaps some more 9100 stuff assuming there is a need for it. Thanks, Kev
Okay, my 9100 keyboard showed up today but much to my suprise it is different from the one commonly displayed in the manuals. It follows the common layout of most modern keyboards yet the keys are marked for the 9100 functions. Anyone's guess if this is a different keyboard chip? This would be the chip to copy if we can. Thanks, Kev
What ever happened to this programmers keyboard? Did you try reading the CPU? Can you read the CPU? There are those of us with that facility if you want to send it out...I'm sure there are folks nearer then me that can do it, but my Xeltek can read most of the 40 pin 80XX micros with ROM on board John :-#)# At 11:16 AM 15/05/2002 -0400, Kev wrote:
Thanks, Kev
Remind me again why we need to reuse the code in the keyboard itself? The service manual documents that the data format from the keyboard is just 7 bit ascii at 1200 baud. Why not just use a terminal? I could loan my keyboard to someone if they want. I won't be needing it anytime soon anyway. -- -/!\- -/!\- -/!\- http://www.stup.net/corey
We are trying to get a keyboard running so that folks can program their 9100's, the built-in keyboard is a pain, plus is limited in it's capabilities... What if an old VT-100 terminal or the like was used? Or a simple interface program...if anyone had a keyboard and a Logic Analyzer they could record the data stream for individual key presses, plus see what happens when the machine is first turned on for any chatter between the keyboard and the base. Anyone know if you can plug the keyboard in after the unit is already on and if it will then find the keyboard with a RESET? John :-#)# At 12:39 PM 09/05/2002 -0500, Rodger Boots wrote:
Thanks, Kev
Cool, this is good info, sounds like I could hook up my old 1200baud terminal or PC via it's serial port to handle this. Once I get my back-up SCSI drive back I shall hook up the LA to the Keyboard output and see what I can figure out. But I still need to figure out my ML4100 RS-232 port... John :-#)# At 01:23 PM 09/05/2002 -0400, Kev wrote:
Thanks, Kev
Anyone have a good picture of this keyboard and any identifying numbers from it? Is it similar to the keyboard from a Fluke 1722A? John Robertson wrote:
At 11:04 AM 08/05/2002 -0400, Kev wrote:
I've gotten several more bits for my 9100FT but I'm missing a keyboard and we've already decided that this is a Fluke specific keyboard.
Does anyone have one for sale/trade/borrow?
I see that a fellow is developing a AT keyboard to Rabbit module software, once that is available it should be fairly simple to emulate the Fluke keyboard if someone could document the datastream. (Rabbits are a neat thing, multiple 232/485 ports, C programamble & fairly cheap).
Hi Kev, Just moved the uploads of yours, was the earlier Intro defective? I can't open it, plus it was only 24K in size. I've deleted it, was it just an earlier version of the 9010training manual you also uploaded... John :-#)#
participants (7)
Corey Stup -
Kev -
Matt Rossiter -
Philip Mayor -
Phillip Eaton -
