9010A Code Generator Question
This is a very handy tool to work with when you want to do some quick tests. I love it. I have just one itty bitty suggestion, unless I'm just doing something wrong. When you generate a test script for a game, say Tempest, the ROM Program names it automatically creates are generally "illegal" when they are compiled through FIDE. I guess it has to be a certain length? So, I just have to edit each ROM program name so that it can compile the script and send it to the troubleshooter. For example, I would normally take a generated name like 136002123 and manually change it to ROM123. http://tech.quarterarcade.com/Tech/CodeGenerator/Default.aspx?g=3057&set=tem... James, would it be possible to add an optional function that could automatically truncate the ROM Program names? Maybe have something where it adds "rom" to the beginning and the last 3 or 4 characters of the rom name to the end? I don't mind doing it manually, or maybe come up with a script of my own, but that would be super cool. Matt _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist
Eventually... Just not a whole lot of time right now because I'm in the middle of re-writing quarterarcade (from the ground up... Reflects things we've learned over the last 5 years of doing business). You can change the program name online in the generator by clicking the Edit link. I know it's a PITA ... And it's not the first time someone has requested this feature. If I get a free couple of hours I'll look into how much work this would be... JB --James Bright www.QuarterArcade.com Restored Arcade Games for your Home
-----Original Message----- From: techtoolslist-bounces@flippers.com [mailto:techtoolslist-bounces@flippers.com] On Behalf Of Matt Rossiter Sent: Sunday, August 27, 2006 3:01 PM To: techtoolslist@flippers.com Subject: [Techtoolslist] 9010A Code Generator Question
http://tech.quarterarcade.com/Tech/CodeGenerator/Default.aspx? g=3057&set=tempest&cpu=5526
By the way, I was able to resolve a tricky problem using the 9010A Code Generator. In the tempest manual I have, if you have a board using the 32k roms, the designated positions are listed as this: 136002-133: D1 136002-134: F1 136002-235: J1 136002-136: L/M1 136002-237: P1 136002-138: N/P3 But according to the Fluke 9010a - the signatures were showing that the positions of the roms should be reversed: 136002-237: D1 136002-136: F1 136002-235: J1 136002-134: L/M1 136002-133: P1 So the book must have a misprint? I was able to catch that problem within 5 minutes instead of spending hours trying to figure it out. Did anyone else know that the manual has this misprint? I have the -04 rev board and the 3rd edition of the manual. Matt On Sun, 27 Aug 2006, James Bright wrote:
JB
Well, Hell- I was working on a board a couple months ago that had these doubled up ROMS that I had to burn a couple for. When I was putting them together, I thought something was funky about the contents/order of them as compared to the 16k ROMS on all the other sets I've seen. I didn't follow the address decoding through, I just assumed the correct chips were being enabled via the wire jumpers. No luck, so I moved onto other things until I read your message. Swapped the ROMS the other way around as in your writeup and BAM - up it comes. There's still a problem with my Y output, but you got me to pull this one off the stack. Thanks! Kerry Matt Rossiter wrote:
JB
James Bright -
K.S. -
Matt Rossiter
