Re: [Techtoolslist] Adapter interface for the DEC-T11 CPU and Fluke pod?
9100A-8086 documents going up now. Note the main manual needs to be split (scanned as a book - 11X17). If someone want to do this great - I don't know how at the moment. If Adobe Acrobat can do that please let me know the process, otherwise if someone else wants to fix that file into 8-1/2 X 11 pages (and the 11X17 schematics) I'm sure someone will appreciate it (besides me). ftp://ttl.arcadetech.org/TTL/Test_Equipment/Fluke/PDFs/Pods/ Thanks, John :-#)# On 04/12/2016 11:32 AM, John Robertson wrote:
Found my 8086 manual - and the addendum info. Will scan and put on TTL in the next day or two.
On 04/12/2016 11:06 AM, John Robertson wrote:
On 04/12/2016 10:56 AM, Jack Rubin wrote:
You may find this helpful - bitsavers is _the_ resource for DEC documentation:
http://bitsavers.trailing-edge.com/pdf/dec/pdp11/t11/T11_UsersMan.pdf
Jack Thanks Jack, I had found that already...currently I need the 8086 manual.
-----Original Message----- From: Techtoolslist [mailto:techtoolslist-bounces@flippers.com] On Behalf Of John Robertson Sent: Tuesday, April 12, 2016 12:37 PM To: Technical Tools Mail List <techtoolslist@flippers.com> Subject: Re: [Techtoolslist] Adapter interface for the DEC-T11 CPU and Fluke pod?
T11 has 16 Address and 16 Data multiplexed together (AD0, AD1, ...AD15).
Hence the 8086. Need a manual...
John :-#(#
On 04/12/2016 10:09 AM, Mike Coates wrote:
depends if the T11 is 8 or 16 bit data - I don't know off hand
On 12 April 2016 at 17:54 Steve Larkins <steve@ukaudiovisual.co.uk> wrote: Is the 8052 a possibility Mike? Ciarcia's Circuit Cellar, Volume 4 Page 61 mentions he used the 8052 as it multiplexed the address data buses.. ( https://books.google.co.uk/books?id=fBuiNpYlyHcC&lpg=PA61&ots=9xCBtO mX2O&dq=8052%20address%20data%20multiplexing&pg=PA61#v=onepage&q=805 2%20address%20data%20multiplexing&f=false ) I tried to figure out if the Atari System 2's T-11 could be exercised with the Fluke but failed to accomplish anything other than downloading some datasheets. Steve Larkins Mobile 07826 553792 On 12 April 2016 at 16:20, Mike Coates <mike@the-coates.com> wrote:
nearest to it is probably the 8086 since that already multiplexes the address and data lines (ad0-ad15). On 12 April 2016 at 15:48 John Robertson <jrr@flippers.com> wrote: Has anyone here figured out an adapter for one of the Fluke 9010 pods to be able to emulate the multiplexed address and data lines of the T11? I am just starting to look at this as I need to access these lines to service an old video game board that used the T11 as the main processor. Any of you not familiar with the DEC-T11 it is a 40 pin device that emulates a PDP11 as far as I can understand. I don't know anything about the PDP11 technically though so am pretty much hacking my way through inventing a troubleshooting procedure, which the manufacturer of the game - Atari (System 2, Paperboy, AFB, etc,) - did not provide. Just flinging this out in the hopes someone here can help. Thanks, John :-#)# -- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
_______________________________________________Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
And the rather nice PCB from Fluke that I will be using for my 8086 to DEC-T11 is shown here: ftp://ttl.arcadetech.org/TTL/Test_Equipment/Fluke/9010and9100Pods/PodAdaptorPCB_651497/ This was part of a kit Fluke made so you could wire-wrap up an interface pod between your regular pod and a UUT that you didn't have a pod for (or Fluke didn't make). The rest of the kit comprised of a blank pod shells, and some gold pins - at least that is all I have left of a kit from one of my purchases a decade or so ago. Shy of Navatech remembers the PCB from his days at Fluke but hasn't seen any in his stock so if someone want to make them others may like that. Or you can use a Vero board cut to size... Of course there is a T11 adapter for the Arduino CPU test project, I may go there as the T11 is compatible with Atari System 2... https://github.com/prswan/arduino-mega-ict/tree/t11 John :-#)# On 04/12/2016 1:56 PM, John Robertson wrote:
John :-#(#
