Re: [Techtoolslist] Xeltek superpro cable?
Can you attach a picture? Mine has a small round hole for the power plug. Justin Sent from my Verizon Wireless 4G LTE DROID David Shoemaker <davids@oz.net> wrote:
Doing a touch more digging looks like I fell prey to a classic blunder.
I got involved in a land war in Asia.
Oh no wait, it was the other one. I bought an eprom burner which uses a dedicated ISA card with no card. Or as the hip kids call it "A paperweight".
-----Original Message----- From: techtoolslist-bounces@flippers.com [mailto:techtoolslist-bounces@flippers.com] On Behalf Of David Shoemaker Sent: Saturday, April 20, 2013 8:04 PM To: 'Technical Tools Mail List' Subject: [Techtoolslist] Xeltek superpro cable?
Anyone have one of these that can describe the cable to me? The unit doesn't have a power supply connector so it must get power through the DB25 connector and from what I can gather it connects to the parallel port of the PC. But I don't know that it will provide enough power from that port alone.
So anyone?
_______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Has a power switch and a db25 plug on the back. Nowhere to plug power. -----Original Message----- From: techtoolslist-bounces@flippers.com [mailto:techtoolslist-bounces@flippers.com] On Behalf Of JJ Sent: Saturday, April 20, 2013 10:02 PM To: Technical Tools Mail List Subject: Re: [Techtoolslist] Xeltek superpro cable? Can you attach a picture? Mine has a small round hole for the power plug. Justin Sent from my Verizon Wireless 4G LTE DROID David Shoemaker <davids@oz.net> wrote:
So anyone?
Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Which SuperPro do you have? There are many versions...If it is the original SuperPro it got the power from the PC adapter card that the 25 pin cable plugged into. This models did NOT use the Parallel Port! I have one of those old timers at the shop, not willing to spare the adapter directly, but can provide you with high rez pictures of both sides if you wanted to make a replacement. Used the XT slot as well, did not need the AT extension. Did not use custom ICs AIR. It may be possible to bypass some of the hardware but I'm not willing to invest any time in figuring it out. The XT card has several ports, some of which are in the Parallel Port range AIR. John :-#)#
Justin
So anyone?
JJ -
