Re: [Techtoolslist] Kurz-Kasch ROM Test II and ROM Test I
I found these items just today. Will go thru what I have tomorrow morning and try to figure out what is what. Pat Sent from my Galaxy S®III -------- Original message -------- From: teeray <teeray@earthlink.net> Date: To: Technical Tools Mail List <techtoolslist@flippers.com> Subject: [Techtoolslist] Kurz-Kasch ROM Test II and ROM Test I Can anyone help with some info on these two devices? Am I correct in assuming ROM Test I - a small device that connects to any Signature Analyzer to preform a full ROM signature. Was made to go along with the Signature II analyzer. ROM Test II - self contained device that displays a full ROM Signature on it's own LED display. Is this correct? Schematics would be great. Any info would be a big help. Also I found the follow in a search of the techtoollist and some signatures of game roms on the TTL ftp site. Thanks to John I have a list of the adapters these devices use, but that's it, no pin out info. of the devices or adapters. Thanks Tim -----Original Message-----
From: John Robertson <jrr@flippers.com> Sent: Jan 6, 2011 11:28 AM To: Technical Tools Mail List <techtoolslist@flippers.com> Subject: Re: [Techtoolslist] Kurz-Kasch ROM Test II
Pat Danis wrote:
John:
Pretty sure I have one of these and a photocopy of the manual as well. Let me dig around and see what I can find. I don't have a scanner......sad isn't it?.......so I will have to get a friend to scan it for you. I'll let you know. May have some sockets as well.
Pat
Well, it now appears to work. Had a couple of bad 244s that I tracked down by assuming someone plugged the sub-boards in backwards and so I simply did a diode check on the small PCB edge connectors relative to common. After replacing the two TTL ICs the device now produces what appears to be a Signature for ROMs inserted in the socket - not a Checksum (rats!).
And it is not the Fluke FIDE Signature, so now I have to track down a file to HP style signature converter to see if the device actually works as intended, my eprom programmer does not generate a Signature for ROM...
Thanks for the offer of a copy of the manual - I will add it, of course, to TTL FTP once it appears.
I suspect this tool is going to sit on the shelf a lot...
Anyone have one of these? I am in need of either schematics or some voltage measurements from the regulator PCB. Just 'won' this off eBay and it really doesn't work (not surprising given the description).
The device looked useful - my assumption was it would generate a CheckSum of an Eprom inserted into the socket - it has four seven-segment displays after all! It uses a Z80 that appears to be wired up as a NOP, but it uses several voltages - perhaps -5 and +12 for the 2708s etc. I only have one socket - 2764-27128, if anyone has any of the sockets I'd be interested in pictures to try to figure out the pinout assuming no schematics or manual turns up that is!
Thanks!
OK, the regulator board turns off the -12 and +12 unless the TEST button is pressed. I assume that is to protect the Eprom...
Still digging...
_______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
----- No virus found in this message. Checked by AVG - www.avg.com Version: 10.0.1191 / Virus Database: 1435/3361 - Release Date: 01/05/11
_______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Pat Danis
