HP 10529A Logic comparator
Has anyone ever made a specific list of 74 series chips that this cannot successfully diagnose? Or does it depend on the circuit in which they're placed (what the inputs / outputs are tied to)? I seem to remember being told once that it can't always successfully diagnose certain logic chips. I don't have enough field experience to know when i use it if the results I'm getting indicate a faulty IC or just an IC it can't reliably diagnose. In fact, so far i don't think it's been of any use to me whatsoever. Obviously i'm ignoring those with more than 16 pins! More specifically, i was looking at some 74LS157's the other day that are part of a 2 to 1 multiplexer prior to some ram ICs. The one that had the WE lines as two of the outputs was showing a fault on both of them, but replacing it made no difference, i thus assumed the comparator was giving a false positive (or negative!). Was this right, or should i really continue to suspect that IC? It's definately in the part of the schematics where my problem lies. Please excuse if it's a bit of a dumb question to some, but i'm merely trying to familiarise myself better with some of the tools that i've picked up over the course of the last few years. Thanks, Martin. If you ever want to (un)subscribe yourself with TTL, you can send mail to: <Majordomo@flippers.com> with the following command in the body of your email message: (un)subscribe techtoolslist or from another email account, besides xxx@yyy.com: (un)subscribe techtoolslist xxx@yyy.com
The output of one IC usually feeds into another (or several others). If the IC it is feeding has a shagged input, it might for example pull the output to ground and will likely make both of them look shagged. Think about how the logic comparator works - all it's doing is driving a second IC with the same inputs as the IC under test, and comparing the results, and any glitches of a certain size get 'stretched' a bit so you can see them. However, (I think) that the output of the comparison IC isn't connected to the rest of the PCB so there could be other stuff there that could cause problems, e.g. lots of capacitance. I'm not a 10529 guru, but I've had occasions where the tests fail, and I've always managed to dream up a reason why. Remember also that some 74 ICs have flip-flops in them, so they can get into the wrong state if you don't start from power up. Phil
-----Original Message----- From: owner-techtoolslist@flippers.com [mailto:owner-techtoolslist@flippers.com]On Behalf Of Martin White Sent: 29 March 2004 20:19 To: TechToolsList@flippers.com Subject: HP 10529A Logic comparator
Thanks, Martin.
One more thing to add... you are comparing like with like? I don't know from experience, but if you compared an 74LS (Low Power Schottkey?) with a 74HC (High Speed ???) then you would probably get output comparison glitches caused by the speed differences. I don't know if this would tigger an output error flash, though. Welcome to analogue digital electronics :-) Phil.
Thanks, Martin.
Yup comparing like for like. One of the guys forwarded a link to me about the bug trap comparator, and that suggests the 157 should compare okay. At the end of the day i'm not overly fussed about the fact the comparator showed two of the outputs as being bad. They both drive the WE lines of two ram ICs each, so i assume they must be good or the graphics would be totally up the creek? Ie, if the WE wasn't letting the ram be written to at the correct times then i guess i'd be seeing a fair bit more of a problem than just the wrong objects being displayed on some levels. Was only really asking as this pcb is starting to drive me nutty! My Fluke doesn't seem to want to know with the boardset, so that's out (ie, i can't get it to run UUT). I've looked all over for stuck bits and can't see any. Then for good measure this evening i've just checked the junction drop of every pin of every IC on the board. Nothing. Starting to scratch my head a little now! All interconnects are also good. Admittedly, the one thing that i haven't done which i'd like to is shotgun the object ram's socket's. Sadly they're the size in between eprom size and ttl size and i don't have any. I guess i could split some normal ones in two, but that's for tomorrow. Had enough for tonight :O) Not sure if i already said or not as i got confused about reply destinations earlier(!), but it's the video generator pcb of an MCRII set. Tron in fact. Martin. On Monday 29 Mar 2004 22:49, Phillip Eaton wrote:
Phil.
Thanks, Martin.
If you ever want to (un)subscribe yourself with TTL, you can send mail to: <Majordomo@flippers.com> with the following command in the body of your email message: (un)subscribe techtoolslist or from another email account, besides xxx@yyy.com: (un)subscribe techtoolslist xxx@yyy.com If you ever want to (un)subscribe yourself with TTL, you can send mail to: <Majordomo@flippers.com> with the following command in the body of your email message: (un)subscribe techtoolslist or from another email account, besides xxx@yyy.com: (un)subscribe techtoolslist xxx@yyy.com
I have found that often the best way to use a logic comparator is the other way around than you may expect- Allow it to show you which chips are good! I found it to be faster and more useful to rely more on the positive results it gives. You will then be left with a short list of IC's that may either be faulty, or giving false faulty results, and you can work on those alone. I have an oscilloscope on my bench so I can back up a faulty reading with the CRO probe straight away. As I test IC's in a section I use a paint marker pen or liquid paper pen to place a dot on the pin 1 corner to indicate I tested it and it is ok. (handy if you come back a week later :) ) First thing I do with a faulty reading is look at the pin on the good IC and the same pin on the test IC with the CRO, and see if they is either too fast or radically different. Apart from voltage offset differences and such caused by the comparator circuitry, you can at least see if there is a similar waveform on the IC pins that test faulty. Narrow spikes and really fast data that give false results can be seen easily. Then depending on the IC type I will either decide it looks ok with a CRO inspection using a pinout/block diagram of the IC, or pull it to test or replace. (eg fast 74161's in video sections, and some other IC's in video output especially run too quick for the comparator) Anyway hope this helps, Best regards, Marc ----- Original Message ----- From: "Martin White" <martin@guddler.co.uk> To: <techtoolslist@flippers.com> Sent: Tuesday, March 30, 2004 8:50 AM Subject: Re: HP 10529A Logic comparator
Martin.
Phil.
Thanks, Martin.
Marc Alexander -
Phillip Eaton
