well, I'm sure you have throught of it already, but can we have bit masks for ram - so you can check memory where only 3 or 4 bits are populated (colour ram on some games for instance), also adding a mask to a ram area would allow you to ID the actual chip e.g. galaxians 4000-43FF mask 0f would isolate a single ram chip, obviously 4000-43FF mask F0 would be the other chip. either that or the ability to ID chips in a memory area 4000-43FF mask 0f = 7P, mask f0 = 7Q (n.b. chip locations are not correct, it's just to indicate what I mean!) for multiple CPU boards, should the memory map / IO etc not be a tree from the CPU, that way you select which CPU socket you are plugged into, and see the memory maps for that CPU ... CPU support - if you can do Z80, S2650 should be a doddle if you want anything done / tested etc, then I'm willing to help - my icon drawing skills are probably not good, but I can program and test things ... (s2650 support for instance) I was going to ask if you had any spare USB chips so I could look at the long delayed project of connecting fluke pods to a PC, but then this would make fluke pods unecessary anyway!
I've put a few screenshots up of the user interface and would appreciate some constructive criticism. The interface isn't set in stone as yet but I'd prefer not to make drastic functionality changes, but I am already considering some layout changes and some small functional improvements. If you ever want to (un)subscribe yourself with TTL, you can send mail to: <Majordomo@flippers.com> with the following command in the body of your email message: (un)subscribe techtoolslist or from another email account, besides xxx@yyy.com: (un)subscribe techtoolslist xxx@yyy.com
mike@the-coates.com
