Help troubleshooting a 9010A
I been having trouble posting to the group... trying again. I have 2 non-working 9010A units. On both they beep once, LEDs flash, then nothing. Hooked up a working 9010A that I borrowed (thanks David). Bus tests fine. RAM returns the following: R/W ERR @ C000 BTS 08 - LOOP? Manual states: If a RAM failure occurs, carefully examine the diagnostic message. The RAM Test is usually sufficient for deducing the failed component directly. It then does not explain how to read the message. :-) I am new to this, so be kind if its a stupid question. I deduced that there is a Read/Write error at C000. How do I "deduce" the failed component? Barry _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
The 9010A service manual has a section (starts in section 4-44) on using another 9010A to repair a malfunctioning 9010A. Copies of them are on the techtools archive or http://www.gamearchive.com/General/Test_Equipment/Fluke/9010A_serv.pdf C000 starts the address range for RAM. _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
barry2ï¼ shilmover.com -
Corey Stup
