Has anyone successfully used the Fluke system on MCR (Tron) hardware? When I try to get a signature from the ROM's, it comes back different every time. When I try to do a RUN UUT, the game self test runs and reports errors with all of the ROMs and occasionally the RAM. This is all happening on a known working board with the watchdog disabled. If I pull the test pod out and put the CPU back in, everything works fine. Oh, and I've also tried two different Z80 pods, with the same results. Any thoughts? Thanks, -Chris If you ever want to (un)subscribe yourself with TTL, you can send mail to: <Majordomo@flippers.com> with the following command in the body of your email message: (un)subscribe techtoolslist or from another email account, besides xxx@yyy.com: (un)subscribe techtoolslist xxx@yyy.com
I thought you had to have a z80AA pod (which I do) or better... but I get the same results you report. What z80 type of pod are you running? JB --James Bright www.QuarterArcade.com Restored Arcade Games for your Home
-----Original Message----- From: owner-techtoolslist@flippers.com [mailto:owner- techtoolslist@flippers.com] On Behalf Of Chris Loggans Sent: Saturday, May 01, 2004 4:20 PM To: techtoolslist@flippers.com Subject: Fluke 9100 on Tron hardware
Thanks, -Chris
I've tried both a regular Z80 and a Z80/AA pod. Same results from both. I'm going to try John's suggestion and change the chip and see if that helps. Thanks, -Chris If you ever want to (un)subscribe yourself with TTL, you can send mail to: <Majordomo@flippers.com> with the following command in the body of your email message: (un)subscribe techtoolslist or from another email account, besides xxx@yyy.com: (un)subscribe techtoolslist xxx@yyy.com
Changing the cpu in the POD to a Z80B did not help. Any more suggestions? Thanks, -Chris --- Chris Loggans <cloggans@yahoo.com> wrote:
Thanks, -Chris
You beat me to it, but i was going to add that a 9010 with a Z80 pod equipped with Z80A processor gives the exact same results too... Martin. On Sunday 02 May 2004 03:40, Chris Loggans wrote:
Thanks, -Chris
Thanks, -Chris
If you ever want to (un)subscribe yourself with TTL, you can send mail to: <Majordomo@flippers.com> with the following command in the body of your email message: (un)subscribe techtoolslist or from another email account, besides xxx@yyy.com: (un)subscribe techtoolslist xxx@yyy.com If you ever want to (un)subscribe yourself with TTL, you can send mail to: <Majordomo@flippers.com> with the following command in the body of your email message: (un)subscribe techtoolslist or from another email account, besides xxx@yyy.com: (un)subscribe techtoolslist xxx@yyy.com
Does anyone have a datasheet for this EPROM? Thanks, -Chris If you ever want to (un)subscribe yourself with TTL, you can send mail to: <Majordomo@flippers.com> with the following command in the body of your email message: (un)subscribe techtoolslist or from another email account, besides xxx@yyy.com: (un)subscribe techtoolslist xxx@yyy.com
Well, after about 6 hours of time invested in this issue, I think I have an answer. Here is what I found in getting there (the long story...feel my pain): I originally started with a working -C000 rev SCPU board which reported the failing RAM and ROM when connected to the Fluke. Not being able to determine why, I moved to a rev -E000 and found the same results. Then I tried a rev -G000 board and this time the Fluke successfully ran the board in RUN UUT mode and was able to produce stable signatures. Assuming the problem to be something Bally/Midway corrected in the -G000 rev, I compared schematics from the two revs to find all of the differences. I then applied all of the relavent modifications (mostly added capacitors on timing and control lines) to a -C000 board and tested again. This did not solve the problem. After double and triple checking my work, I decided to put that board aside and try yet another -G000 board to make sure that the success on the first one was not a fluke (no pun intended). Well, this time, it did not work! Whatever made it work on the first -G000 board was obviously different or missing from this one. Then it dawned on me... the board that I had success with had EPROMs that I burned and all of the others had factory EPROMs. I then decided to move the EPROMs from the board that worked to an unmodified rev -C000 board and that board now worked too! That's when I asked for the datasheet for the EPROM's that I was using (Thanks Rodger!!). It turns out that my EPROMs are 250ns and all of the originals are Intel 2764-4's which I believe are 400ns. For whatever reason, the slower EPROMs work fine to run the board in game mode, but appear to be too slow for the timing on the Fluke pod. In any case, it looks like the short term answer to the problem is to get a faster set of EPROMs to test with and then replace the originals when you get it working. I still have some more testing to do and I'd like to burn another set of EPROMs to double check my results, but this is where I am right now. I hope this will help the next time someone needs to debug an MCR boardset. Thanks, -Chris If you ever want to (un)subscribe yourself with TTL, you can send mail to: <Majordomo@flippers.com> with the following command in the body of your email message: (un)subscribe techtoolslist or from another email account, besides xxx@yyy.com: (un)subscribe techtoolslist xxx@yyy.com
Anyone know anything about an ice-technology GLV_COP programmer. It has 8 x 40 pin sockets, and is apparently for programming COP8 MCU's, but does anyone have more info on it - does it only do COP8's, or will it do the full range of PAL's and Eproms etc that the GLV-32 does ? I only ask because I just got one on ebay for £3, and wondered if it was likely to end up as a pile of 40 pin ZIF's or whether I could actually use it for programming the same set of devices as the GLV-32 models (I assume 32 since it has 32 pin sockets) If you ever want to (un)subscribe yourself with TTL, you can send mail to: <Majordomo@flippers.com> with the following command in the body of your email message: (un)subscribe techtoolslist or from another email account, besides xxx@yyy.com: (un)subscribe techtoolslist xxx@yyy.com
Is the UUT using a Z80A(or B)? The regular Z80 pod doesn't like the faster Z80's, you need to upgrade the CPU in the pod to a Z80B...I think that might work. John :-#)# At 1:20 PM -0700 5/1/04, Chris Loggans wrote:
Thanks, -Chris
Can you simply upgrade the Z80 pod to a Z80B by swapping the chip? Hmm. I stopped working on MCRII boards because I couldn't get this running and had to move on to other stuff. But I'd really like to get back on them. --James Bright www.QuarterArcade.com Restored Arcade Games for your Home If you ever want to (un)subscribe yourself with TTL, you can send mail to: <Majordomo@flippers.com> with the following command in the body of your email message: (un)subscribe techtoolslist or from another email account, besides xxx@yyy.com: (un)subscribe techtoolslist xxx@yyy.com
Chris Loggans -
James Bright -
Mike Coates -
