Re: [Techtoolslist] Fluke 9010A Install with FIDE
I tried to connect to my 9010a and laptop using xp and received a buffer overrun or overflow message on the 9010. Any ideas on what the cause might be? I was using a null cable. Justin Sent from my Verizon Wireless 4G LTE DROID Matthew Rossiter <matt@rossiters.com> wrote:
Has anyone gotten Fluke FIDE to work in Windows 7? I've always just used my old Win XP laptop with a USB/Serial adapter and it works great.
On 4/12/2013 11:13 AM, Theron Troxel wrote:
I found out what I was doing wrong. Didn't have a null modem cable adapter. Ended up ordering a serial cable adapter, which I knew I didn't want. Will try again with the correct part.
________________________________ From: Theron Troxel <troxelone@yahoo.com> To: Technical Tools Mail List <techtoolslist@flippers.com> Sent: Friday, April 12, 2013 1:07 PM Subject: Re: [Techtoolslist] Fluke 9010A Install with FIDE
________________________________ From: Theron Troxel <troxelone@yahoo.com> To: "techtoolslist@flippers.com" <techtoolslist@flippers.com> Sent: Monday, April 1, 2013 5:50 PM Subject: [Techtoolslist] Fluke 9010A Install with FIDE
Trying to get my fluke to respond to my computer. I have a USB-to-RS232 cord, and my computer recognize the cord. I went to settings on my computer and set it to com1 and matched everything to the computer and fluke.
Wrote a simple program that just displays "test" and tried sending it through the Fluke FIDE software. The fluke never responds to when I send the program. I don't get any errors of any type on the fluke. However, on the Fluke FIDE I get the following error:
Starting process... WARNING: Include file already exists. File may have been included multiple times, or two files with the exact same file name may exist. It is recommended that you give your files distictive file names. C:\Program Files (x86)\Fluke FIDE\Scripts\test.9lc -> C:\Program Files (x86)\Fluke FIDE\Internal\test.9lc (exists). ERROR: Could not create batch file C:\Program Files (x86)\Fluke FIDE\Internal\9lc.bat. Permission denied Batch file processing failed. _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Flow control is probably off or set wrong on computer end. Open up control panel, system, hardware, com ports. Selects your com port and port settings. Flow control should be XON/XOFF for software flow control or Hardware for hardware flow control. Use whichever matches the programmer setup. If you're using Hardware and it doesn't work your null modem cable may be wired wrong. Good luck. On Fri, Apr 12, 2013 at 5:36 PM, JJ <rugd2go@comcast.net> wrote:
Justin
Correct baud rate, stop bits, parity on computer and 9010? Hi all, I just joined the Fluke club this week - got one with a 6502 pod and a 8088 pod and some manuals. Pods test OK. Going to try and do some RAM, ROM and bus tests on some arcade boards next. Ordered a null modem cable so waiting for that to arrive before trying the FIDE with a PC. Cheers, MarkG On 13/04/2013, at 8:36 AM, JJ <rugd2go@comcast.net> wrote:
Justin
JJ -
Mark Greenway -
