Did you activate the port on the Data I/O? You do have to press the command sequence each time you turn the 29A on...I have one version of firmware that automatically puts the unit in RS-232 mode. Also make sure that the programmer is set to the same speed (19,200 is best) as the PROMlink. Lastly, use one of many terminal programs and set the 29A to RS-232 and monitor the terminal program to see if you get a result. John :-#)# At 02:10 PM 30/04/2003 +0000, pc2jamma wrote:
Hello
I have one Data io 29A with Unipack 2. I'm trying to put it working in remote modem with PROMLINK software, and the software telling me that the programmer is not connected.
I checked all connections and configurations, and I'm using a null modem cable as described on it's user manual.
Do you guys have some cue on that ? I was noticed that it has some Firmware EPROMs update. Is it available to download or could someone send it to me ?
Thank you
Jose Luiz Martins
How to subscribe or unsubscribe from TTL To do either you send email to "MajorDomo@flippers.com" and in the body you state either "Subscribe techtoolslist" or "Unsubscribe techtoolslist", note that the Subject is "" (Blank)... FTP site is: ftp://ftp.flippers.com/TTL/
pc2jamma
