If money were no object, and you needed something that would program just about darn near everything. Pals, Gals, PLD's, Old TI eproms, newer eproms. What would you get? Kevin _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
I'd be looking at the top-end of the Elnec range - http://www.elnec.com/. The nicer models seem to be FPGA driven so very upgradeable, the software is nice and very well supported too. I've got a Smartprog2 which is nice but misses out the TTL/RAM testing features (with a device ID check locking out the features in software, so it's possible to hack around it[1]). You'd have to spend a bit of time on the supported device list but the hardware design is such that pretty much anything can be supported. If you supply them with a couple of blanks and a datasheet they will also add progger support. I believe this may exist only whilst your device is under warranty though. cheers tim [1] My first elnec was bought via ebay and was a top-end model that did everything including RAM/TTL/Test vectors. After a couple of months the latest progger software was installed and wiped the FPGA. It turned out the device was a chinese bootleg and elnec disabled it. I eventually obtained a refund from the ebay seller and bought a BK Precision 844USB which is a rebadged elnec, but a slightly less capable model than the bootleg I'd initially bought. Elnec wanted me to spend about £600 to replace my boot with an official version which I thought was too much given my limited requirements, so I went for a model a couple of steps down. And even though this is considered a "lite" version, it's rock solid and has never refused to blow any EPROM) On 2 June 2010 16:59, Kevin Moore <talon.k@gmail.com> wrote:
What would you get?
I've been looking at this one as well. XPRO-5000, not the E http://www.logicaldevices.com/ On Wed, Jun 2, 2010 at 11:25 AM, Tim Matthews <trmatthe@gmail.com> wrote:
cheers tim
What would you get?
I second this (the elnec) - I have the Dataman-48PRO+ which is basically the same thing under a different name. http://www.dataman.com/WebPages/ProductView.aspx?pid=627 I've sent them quite a few devices to add including the 82S114/5, PLS153, several different variations of static rams simply for testing, and others. The support team is great to work with. I have to throw in a big BUT though. You need an expensive adapter to do 2708's and TMS2716's and you need an expensive power supply upgrade for *some* bipolar proms - I haven't had to do that yet. It's great for going through a pile of TTL and static ram pulls and weeding out the flakey ones. The programmer can fit nicely in your desk drawer too. :) The best bang for your buck would still have to be the Data I/O 29B with the unipak if you just want to burn your typical video game roms and bipolar proms. Matt On 6/2/2010 9:25 AM, Tim Matthews wrote:
cheers tim
What would you get?
I have a Dataman-48PRO+ now as well. When it came to the expensive adapter for the 2708's though, I phoned them up, asked them a couple of questions, explained that I was already pushing my budget as it was for hobby use and by the time I'd umm'd and arr'd a bit they knocked it down by half price (the adapter not the programmer), thus making it nowhere near as expensive :) That set's then aside for starters in my books. Some companies switch off the minute they realise you're a hobbyist. They did the opposite! Anyway, I guess that's not really an "if money were no object" programmer as it's only £700 (+17.5% VAT incidentally), but it's still pricey. Martin. PS: I honestly thought the new device addition thing was free for life as I remember asking whose life, mine or the programmers :) (the programmers obviously!) On 2 Jun 2010, at 19:39, Matthew Rossiter wrote:
cheers tim
What would you get?
Hi Matt, What software do you use for the Dataman? Is it branded Elnec? I believe I got a download link from BK Precision but I knew it was an Elnec rebadge so I just kept my original software. I was wondering whether the device lists are significantly different between the two if they have their own branded ver. I do also have a Data IO 29b for the old stuff :) I forgot to mention that. cheers tim On 2 June 2010 19:39, Matthew Rossiter <matt@rossiters.com> wrote:
This is what the main MAME dumper uses to read stuff: http://guru.mameworld.info/MyStuff/index.html You can see what he can dump here: http://guru.mameworld.info/MyStuff/packages.html Pretty impressive. Joe --- On Wed, 6/2/10, Kevin Moore <talon.k@gmail.com> wrote: From: Kevin Moore <talon.k@gmail.com> Subject: [Techtoolslist] Chip Programmers To: "Technical Tools Mail List" <techtoolslist@flippers.com> Date: Wednesday, June 2, 2010, 10:59 AM If money were no object, and you needed something that would program just about darn near everything. Pals, Gals, PLD's, Old TI eproms, newer eproms. What would you get? Kevin _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
What would you get?
I'd probably uprgade to the latest BP-- http://www.bpmmicro.com/1710.html I have a couple of the older BP-1200's and they've been flawless over the last ~10+ years. Just for fun I requested pricing on the 1710. I suspect it will be in "pretty nice used car" range. ;-) -Clay _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Clay Cowgill -
Joseph Magiera -
Kevin Moore -
Matthew Rossiter -
Tim Matthews
