Fluke Model 90 µP Microprocessor Board Tester Showed up on e-gay recently. The description talks about in circuit testing, but does not specify the cpu type. Wonder if it is usefull. Any comments? Mike Text of auction reads: The Fluke Model 90 µP Board Tester is a hand-held, easy-to-operate, tester used to diagnose faults in microprocessor-based devices. The tester is a Direct Memory Access (DMA) device emulator that connects to the microprocessor in the UUT (Unit Under Test). The microprocessor does not have to be removed from the circuit. The tester forces the DMA and WAIT lines on the UUT bus, taking control of the bus from the UUT's microprocessor. Power is supplied by either the +5 volt line at the UUT microprocessor or by and (optional[not included]) external power supply. No connection is required to the UUT other than the microprocessor clip. The Fluke 90 performs the following: Bus Test to determine if any bus line is stuck high or low, or shorted to other bus lines. Memory Test to determine if RAM can be written and read and if ROM contains the proper bit pattern. I/O Test to determine if I/O addresses can be written and read. QuickTrace(tm) to identify the signal name of an address, data, or control signal line and allows the type of signal line to be tracked in the UUT. Detect selected events on the UUT bus by setting and enabling Break-Point, Frame-Point, and SYNC/Trigger Interface functions. Loads the UUT memory over the Remote Communications Interface. Dumps the contents of the UUT memory to a remote terminal or computer via the Remote Communications Interface.
-----Original Message----- From: James Marous [SMTP:JMarous@midmark.com] Sent: Friday, January 14, 2000 12:53 PM To: 'TechToolsList@flippers.com' Subject: RE: Signature Analyzers
On the subject of KK units.... I have a KK ROM tester, no documentation, it just has 2 rows of machine pin sockets on the top and inputs for the sig analysis connections. I always assumed is just calculates sigs on the ROMs, but I never really knew, or used it for that matter. Anyone know about this one?
I also picked up a Bugtrap DRAM tester on Fleabay for $10, works great. Does everything down to 4116s... It is configurable for the timing and everything. Works great for me, as my current eprom burner/chip tester doesn't handle triple power supply parts. If you get a chance to grab one, I would definitely go for it. I think it's the Bugtrap model 8000.
James -----Original Message----- From: Kev [mailto:KKlopp@EROLS.COM] Sent: Friday, January 14, 2000 3:20 PM To: TechToolsList@flippers.com Subject: Re: Signature Analyzers
For some dumb reason I have several of them, I have the HP 5004 and 5006, a bug trap sig analyzer and a Kurz Kasch model. All are basically about the same, at least as much as I use them. Honestly, I find I seldom use signature analysis. About the only time it really comes in handy is working on vector mathboxes. But it's nice to have it for well documented projects, like the cinematronics boards.
James
Gosh I thought I was the only "dummy" with 3 sig analyzers in the house.
I've got the Bugtrap (My personal favorite) Kurz Kash and the Cat Box.
If anyone is interested in the KK box I'll sell it or trade it. I've also go the KK eprom copier & several modules if anyone has any need for that (read vintage equipment).
My use of a SA?
Well I was fighting enough with Bally pinball boards MPU 17 & 35 that I went thru & did some SA.
I started to do Pac-Man but the buffering circuits complicates SA implimentation. I have used the SA on Pac-Man to catch funky 74ls161's in the timing section. This is a rare case where a using an O-scope the way I do (probe, see if the signal is full range & looks "normal") would not have found the faulty 74ls161, since the outputs were toggling & appeared to work, they just were not correct.
I have unsuccefully SA a Battlezone Math box before.
The SA is an okay tool, it will be more powerful the more people document & share Signatures. I'd take an O-scope of a SA any day but the SA is cheaper and depending on your focus not a bad tool.
Kev mowerman@erols.com http://www.erols.com/mowerman
I suggest that you collectively align & don't bid against each other, after the auction is over then purchase several units. I mentioned to the seller that if the machine did what I expected it to do that I would possibly purchase his entire stock, but I got no response & see it on E-bay again. Sounds like it would be for the Z80 CPU. Nice unit! Carefull, now we all will be bidding on it!
I would like to purchase one and although I am in the UK I would willingly pay shipping. So if anyone is going t bid for them Please keep me in Mind. I am currently working on a sig analysis chart for a Namco galaxian Board but I,m having difficulty getting sig's for the video Ram can any-one assist please. I will make the charts available to the group when finished. I would need to know where to send them and in what format Thanks pete (INVADAR)
I can do PDF stuff if need be, might be getting into Galaxian board repairs myself soon.
I have a number of Kurz Kasch signature charts for various games, including Galaxian (Midway) I could take a photo and post it somewhere or email to you. Would prefer to send to Spies for archiving with someone that pdf's stuff, no scanner here...
Kev -
mike_ranger@dofasco.ca -
Peter Davies
