Fluke 9000 Pod (Z80) UUT ribbon cable
Happy New Year to all! There's not much in my TTL archive about this, and varying opinions/options upon web searches but I wanted to see what the current thought are on this topic? I have a Z80 pod that works depending on how you position the pod/cable. If it's working you can twist the cable slightly at the pod and it will stop working. I have pulled it apart and did notice that the upper level ground foil did split and I bridged this will wire/solder. Still seems to be doing failing. The 40 pin dip side seems fine - any options? Has anyone re-terminated the pod side? Any replacements available? I see some pages reference just using a 40 pin flat cable - has anyone tried this and if so what are your experiences? Thanks, Greg _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
I believe Raymond Jett (Channelmanic or Channelmaniac on other forums) sourced some of that cable. I don’t know if he is on here. I will ask and see if he has any left Pat Sent from my iPhone
Thanks, Greg
I have a few NOS z80 cables but I'm not really interested in selling. Sorry. I don't know where else you'd source NOS replacements. Long ago Paul Swan made an adapter PCB. Info on KLOV IIRC but like other efforts used normal 0.100 header pins, which is a bad idea IMO as they will damage the UUT socket. If I was making one I'd use the Aries headers: https://media.digikey.com/photos/Aries/20-600-10.jpg They sell them in fork (pictured) and leg. I always figured you could wire one up to exactly reproduce the dual/grounded cable Fluke cable and then pot the top of the Aries socket Work for sure but I suspect there was a fair amount of manual labor that went into the original Fluke cables. Good luck! Tony _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Also fixing at the pod end is pretty doable. Compared to fixing at the probe end. Also make sure you check for bad solder joints on the pod header pins. _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Thanks for all the responses - I read through all, but I am just responding to the latest. As others have stated, the straight through cable is valid - I found a use for the spare Ms Pac 40 pin connector cables I have laying around. Since I do not have any 40 pin DIP plugs on hand I lopped of one end of the Ms. Pac cable and crimped on a header socket for the pod side and all seems well at this time. The header pins on the Pod side are still solid, but I did verify on the old cable that a couple wires on each end are loose/broken at the connector so I should be able to save the cable. It will likely take some time and should be a whole pile of fun getting a new end on it, but the UUT side is fine so it will be worth saving it. For now at least I can continue my tests. Now I need to look at the other Z80 pod I have as a spare, it was passing self test for the first minute or so and then failing after that. Tonight I clamped the plug into the socket and let it sit looping the test and it seemed to stay in a passing state. I suppose it was either a dirty socket or pins but I didn't wiggle the cable around. I'll see how it acts tomorrow. Thanks, Greg _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
I assume the engineers at Fluke chose the updated dual cable for the /AA (and QT) for a reason.
Greg Baumgratz -
Pat Danis via Techtoolslist -
