If you could wish for anything....
I'm trying to design too much stuff and resulting in getting nothing done. So let's see what interest there is in any of this stuff. Test monitor. A small (12" or under) black and white vector monitor that couldn't be damaged by bad boards. I have a small number of vector yokes that would fit a 20 mm neck b&w tube. A bullet proof deflection board is easy enough for a small monitor. I also have 300+ Sony flybacks laying around that could power a small tube. I even have some 5" tubes, but that may be too small. Any ideas if this is a worthwhile project to pursue and what size tube would be ideal. Replacement for Keltron. Kind of goes back to the 300+ Sony flybacks above. Pursue it or drop it? Replacement for 19 KV vector high voltage power supplies. Supposedly everyone is about to announce this one. Mine is based on the flyback used in the WG K7000. Turns out there is a company that makes flybacks (HR Diemen) that makes a replacement for the K7000 flyback. For all I know they might even be the OEM for them. MCM Electronics sells the HR part at a decent price. The advantages to using this particular part, as I see it, are 1) availability, 2) price, 3) already know it is likely to work with our tubes, 4) has a built-in HV bleeder to discharge the CRT, 5) can be it's own isolation transformer if run off the power line. Should I keep running with this or let others come out with competing products and hope they work? Entire vector monitor. I presently have possible CRT/yoke combinations tracked down for 19", 25", 27", and 33". I think I also have an indestructible deflection board design. Cut bait or run? What's the most likely to be useful sizes? Replacement G08 deflection board. Same indestructible design I mentioned above. Do it or chew it? Replacement for Fluke 9010A that interfaces a Fluke pod to a computer. Any need for it? Universal pod for Fluke 9010A. One pod with interchangeable cartridges to handle just about any processor used in arcade games, including a few that Fluke never supported. Would probably kill the market for Fluke pods (great...after I just bought a bunch of them...). Any interest? Any interest in anyone helping to build any of this? Should I just go back to bed? I obviously can't do all of these simultaneously, I have neither that kind of time or resources to do it. But I'd like to get a feel for what is most likely to be useful. What is most likely to sell. (What is most likely to pay for doing the rest of it).
My Votes in order of good to me: Small Vector monitor for bench, 12" or even the 5" would be fine for when I am working on boards and could really use my scope for something else. The two Fluke projects sound good to me. I would like to be able to utilize this $2000 piece of equipment next to my bench for something other than email. Though I also have completed my fluke collection, the setup time to use it is daunting. Universal replacement HV unit. Entire vector monitor in 33" would be very nice. But a totally niche product. My $.02 David --------------------------------------------------------------------------- ** To UNSUBSCRIBE from vectorlist, send a message with "UNSUBSCRIBE" in the ** message body to vectorlist-request@synthcom.com. Please direct other ** questions, comments, or problems to vectorlist-owner@synthcom.com.
