Re: [Techtoolslist] 6800 to 6502 pod combo ROM?
remember that to convert a 6800 pod to 6502 you maust change some jumpers, not the only one on the eprom's higher address line ----- Original Message ----- From: Theron Troxel Sent: 12/29/13 09:41 PM To: Technical Tools Mail List Subject: Re: [Techtoolslist] 6800 to 6502 pod combo ROM? I had a question on this, too. I am trying to convert my 6800 to 6502 over the weekend and having problems getting it to work. Can you use the original ROM, and if so, how? I tried tying pin 19 to high, and my 9010a just beeps and won't turn on. If I cut the trace the fluke turns on, but then I get a TIMEOUT error on the pod when I self test. I would appreciate any help on this. On Saturday, November 9, 2013 2:32 PM, david grohowski <electronicamuse@aol.com> wrote: Excellent, thanks. david grohowski electronicamuse@aol.com -----Original Message----- From: John Doe <zabanitu@mail.com> To: techtoolslist <techtoolslist@flippers.com> Sent: Sat, Nov 9, 2013 2:39 pm Subject: Re: [Techtoolslist] 6800 to 6502 pod combo ROM? eprom file is 540344 http://arcarc.xmission.com/Test%20Equipment/Fluke/6800pod/ it already contains firmware for 6800/6502 cpus. just toggle eprom pin 19 (a10) _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com ht tp://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/ _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
I followed the guide at Klov and made the cuts and added the jumpers. Just wondering what I did wrong.
Excellent, thanks.
it already contains firmware for 6800/6502 cpus. just toggle eprom pin 19 (a10) _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
REALLY stupid question, but you did also replace the 6800 with a 6502, right? On Dec 29, 2013 5:18 PM, "Troxelone" <troxelone@yahoo.com> wrote:
On Saturday, November 9, 2013 2:32 PM, david grohowski < electronicamuse@aol.com> wrote:
Excellent, thanks.
Is there a difference between a 6502a and a 6502p? I took a 6502p out of my working Centipede PCB and put it in the pod.
On Dec 29, 2013, at 6:32 PM, Rodger Boots <rlboots2@gmail.com> wrote:
REALLY stupid question, but you did also replace the 6800 with a 6502.
6502P would be 1MHz in a plastic case. 6502A is a 2 MHz part (needed especially for vector games). On Dec 29, 2013 6:53 PM, "Troxelone" <troxelone@yahoo.com> wrote:
I went back and double checked my work on cut traces and jumpers and didn't see any errors. I replaced the 6800 with a 6502a, and tied pin 19 to VCC. Can I use the original ROM in the 6800 POD? If so, is it more than just tying pin 19 to VCC? Thanks again! On Sunday, December 29, 2013 7:27 PM, Rodger Boots <rlboots2@gmail.com> wrote: 6502P would be 1MHz in a plastic case. 6502A is a 2 MHz part (needed especially for vector games). On Dec 29, 2013 6:53 PM, "Troxelone" <troxelone@yahoo.com> wrote:
John Doe -
Rodger Boots -
Theron Troxel -
Troxelone
