Anyone have a spare good cable or know of a source? Mine is flaky and I need to replace it. Thanks, David _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
________ Usually the problem is right at the the 40 pin IC header and you can easily crimp on a new one if you don't have the twisted ribbon wire. You can even order them from Digi-Key with the 40 pin plug end terminating in the 40 pin IC socket.
The advantage with the twisted is you can run a cable of about a foot. With flat ribbon 8 inches is pretty safe. I always plug a 40 pin IC socket (with flat solder tails) onto the UUT end to act as sacrifice pins. Easier to replace that one! John :-#)# -- John's Jukes Ltd. 2343 Main St., Vancouver, BC, Canada V5T 3C9 Call (604)872-5757 or Fax 872-2010 (Pinballs, Jukes, VideoGames) www.flippers.com "Old pinballers never die, they just flip out" _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist FTP site is: ftp://ftp.flippers.com/TTL/TestEquipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
