---------- Original Message ---------------------------------- From: "Peter Fyfe" <peter@bombjack.freeserve.co.uk>
Dear all,
I'm obviously in the minority here. My signatures don't match the Atari guides using the CAT box.
Sounds like a the problem with your NOP card. Either the one I mentioned in my other post, or some other problem. Is the "unstable signature" led lit or flashing when you take your measurements? I seem to recall seeing incorrect signatures when I used the NOP method.
Granted, i get the same signatures for the mathbox on the vector games but for the rest of the board i get completely different signatures.
This also points to your NOP card, because the mathbox doesn't use any signals from the NOP card when in SA mode. <snip>
-----Original Message----- From: Chris Loggans <chris.loggans@deltasolutions.com> To: 'TechToolsList@flippers.com' <TechToolsList@flippers.com> Date: Friday, January 14, 2000 4:39 PM Subject: RE: Signature Analyzers
Every time I've used my HP 5006, the signatures have matched the Atari documentation.
-Chris
-----Original Message----- From: Jon Raiford To: TechToolsList@flippers.com Sent: 1/14/00 11:27 AM Subject: Re: Signature Analyzers
Ok, thanks. I guess it really is the right one to go after. Is it true that the it reports the same signature as a cat box? I've heard two different stories, so I wasn't sure what to believe :)
Thanks again
Jon
At 08:20 AM 01/14/2000 -0800, you wrote:
As far as I know - any signature analyzer should do fine. The HP 5004A has the most documentation available online as far as troubleshooting video game boards.
I bought the HP 5004a for $100 although you may see it for slightly less on ebay. I got mine simply because most of the documentation on using the Cinematronics exorsizor mentions this particular model.
Just my 2 cents.
_____________________________________________________________________
On Fri, 14 Jan 2000, Jon Raiford wrote:
I have decided that I should get a Sig. Analyzer. What is the one to get? I keep seeing people talk about the HP 5004A, is that was I should be targeting? I'm sorry if this has been discussed to death already, I just now finally joined this list. Also, what should I expect to pay for one?
Thanks, Jon
Mark Shostak
