There is a sample PP test script in the FTP archives. THere is also a Z8000 pod manual and an addendum (might be what you are looking for) up in ftp/flippers.com under TTL/Test Equipment/Fluke/PDFs . John :-#)# At 10:12 PM -0400 7/13/05, tony wrote:
just bought a fluke z8000 pod it has a z8002 chip in it with a adapter in the pod on the cable to the uut it is 48 pin according to the manual it should have a 48 to 40 pin adapter to go to uut i did not receive this with the pod does anyone have the adapter or plans on how it should be built manual does not cover this . would like to try to adapt this for use with pole position any help with the adapter or on using it with pole boards would be great or if anyone has written any test scripts thanks tony
-- John's Jukes Ltd. 2343 Main St., Vancouver, BC, Canada V5T 3C9 Call (604)872-5757 or Fax 872-2010 (Pinballs, Jukes, VideoGames) www.flippers.com "Old pinballers never die, they just flip out" _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist
tony
