RE: Gottlieb / Q*bert scripts for the 9010A/9100
I'm coming into this thread half way so excuse me if i'm getting the wrong end of the stick. RomIdent does indeed use Standard CRC32, With Thierry's I wrote a VB front end that imported the Romident database into access and then took a file from disk or memory (It was an add on tool for my eprom programmer) and calculated it's CRC32 and scanned the DB for matches. The one down side I found was the diffence with how C++ and VB handle the datatype, it took a while to realise that VB had inverted all of the CRC values..... Chris -----Original Message----- From: Phillip Eaton [mailto:inbox@phillipeaton.com] Sent: 08 May 2002 22:51 To: TechToolsList@flippers.com Subject: RE: Gottlieb / Q*bert scripts for the 9010A/9100 AFAIK, the signature that Rom Ident uses is a standard CRC-32 calculation, which is calculated in an identical way to CRC-16 and CCITT CRCs, using all bits of each byte in the file. The polynomial may be different (i.e. more bits for CRC-32), but the technique is the same for any CRC/Signature calculation. Have a search for CRC-16 and CRC-32 on Google, you get back loads of results. WinZip uses CRC-32, as does MAME, to see the CRC-32 for a file, zip it up in WinZip (8.0?) and set the configuraiton options to show the CRC. You'll see it's 8 hex characters i.e. 32 bits. Cheers, Phillip Eaton
-----Original Message----- From: John Robertson [mailto:jrr@flippers.com] Sent: 08 May 2002 22:44 To: Phillip Eaton; TechToolsList@flippers.com Subject: RE: Gottlieb / Q*bert scripts for the 9010A/9100
Home today fighting a small chest infection...
I don't think these ROM Signatures generated by the base numbers are true "Signatures" after all. Note that the coding for them does not follow the convention of using HP's ACFHPU, rather the "signature" generated uses standard HEX nomenclature.. Now I wonder what this number actually is...I'm going to try to use my new Arium ML1400 Logic Analyzer to see if I can find the section of code in the base that actually is used to create the ROM signature and report back.
I think it is more likely a signature similar to the one ROMIDENT uses... anyone know it's root formula?
At 10:06 AM 07/05/2002 +0100, Phillip Eaton wrote:
Ah ha! You've just spotted the reason for my previous question - What's the polynomial?
I worked out the Cat Box polynomial directly from the PCB, you can actually _see_ the address counter and the XOR feedback points. Apparently the Cat Box polynomial is the same as the HP one.
Now it gets a bit confusing... (Especially as I've not actually had time to get stuck into my Fluke and confirm all of this!)
/As far as I can see/ The Fluke creates a signature with a similar procedure to a boring old checksum, by reading each byte of a region of memory space and performing a calculation on it to produce a single 16 bit signature. To create the signature, it right shifts each bit of each byte into the polynomimial XOR 'circuitry'. On the Cat Box the 'circuitry' is physical, but is probably software on the 9010a for reasons shown below.
On a Fluke, there seems to be a bit of general confusion as to where the calculation is done, in the pod or in the main unit. I would be very surprised if it were done in the pod but I could be wrong. (I hope to have a look myself in the summer, when I've finished college...)
Anyway, the Cat Box performs Signature /Analysis/, which also produces a signature, but not by reading in a chunk of bytes and creating a signature from them via software.
Using a probe, it reads the chain of bits that occur at a particular point on a PCB when the address bus is ramped from 0 to FFFFH. To test one part of a circuit e.g. a single ROM, you would tie a sig analysis start and stop line to the chip enable of the ROM which in effect maps to that ROMs address space only.
If you point the probe at the one data line of the ROM, you will get a stream of bits which you can XOR in a similar way to the standard Fluke signature. BUT the calculation will only be performed on one bit of each byte as there are 8 data lines and you only have one probe! Thus, you get 8 signatures per ROM as shown in the Atari Cat Box signature reference for each PCB.
A Fluke signature is an improved way of testing a ROMs integrity over a checksum, but it can't be used to analyse anything other than a fixed areas of memory space i.e. ROM. Signature /Analysis/ can test /any/ digital part of a circuit as long at it derives from the processor's address and data decoding (i.e you can't do the video circuitry).
My program uses a software way of calculating the signature, but it emulates the Atari probe hardware i.e. by testing only 1 bit of a byte and thus it is an emulator, as opposed to just a signature generator.
I originally wrote it to do the 8 bits of a ROM, but this added an extra loop, and all I was really trying to do was show how it worked, so I went back to just one bit for clarity.
Note BASIC has no bitwise operators so the code is a bit cumbersome, if you rewrote it in C, or even better Forth, it would be a fraction of the size.
You could quite easily modify my emulation to either create all 8 checksums together like the Cat Box or pass all of the information from each byte serially into the calculation like the Fluke (if you knew it's polynomial).
Cheers, Phillip Eaton http://www.phillipeaton.com
---- Original message ----
Date: Mon, 06 May 2002 21:45:41 -0700 From: John Robertson <jrr@flippers.com> Subject: RE: Gottlieb / Q*bert scripts for the 9010A/9100 To: "Phillip Eaton" <inbox@phillipeaton.com>, <TechToolsList@flippers.com>
Hi Phillip,
I just tried your emulator on a bunch of Asteroid files and compared them with the signatures on the 9010 and I do not get the same results... Does it not setup the same Signature that HP designed and thus should it not give the same results for any file as the Fluke would do on a ROM signature test? The signatures generated by your emulator are consistent - identical files give identical signatures...
Might I ask what the "Bit number <0 - 7>" refers to in the emulator?
At 11:08 PM 06/05/2002 +0100, Phillip Eaton wrote:
I wrote one of these a few years back. It's part of my Atari Cat Box signature analysis write-up which is held at http://www.gamearchive.com/video/manufacturer/atari/vector/s ignatures/
It includes a very simple program source code (to aid understanding) to do what you mentioned in MS DOS QBasic for the Cat Box.
You could quite easily use it as a base to write your own, or simply change the polynomial in mine and it'd do what you need.
How did you work out the ploynomial?
-----Original Message----- From: owner-techtoolslist@www.flippers.com [mailto:owner-techtoolslist@www.flippers.com]On Behalf Of John Robertson Sent: 06 May 2002 22:03 To: TechToolsList@flippers.com Subject: Re: Gottlieb / Q*bert scripts for the 9010A/9100
What we need is for some bright person to write a simple utility that converts data files to signatures. The signature formula is fairly simple and if combined with Bill Ung's ROMSUM would be a nice tool for our package. If you don't know ROMSUM it is a dos utility that will give a checksum listing plus the ROM size for a single or group of files...
The Signature process is a CRC process that uses the following feedback equation: X(to the 16th) + X(to the 12th) + X(to the 9th) +X(to the 7th) + 1 or P(X) = X(15th) + X(9th) + X(7th) +X(4th) + 1
So who wants to make a simple (not for me!) binary program that allows one to input a file and outputs it's signature?
At 09:11 AM 06/05/2002 -0400, Kev wrote:
Anyone written any test scripts for these or at the very least have some checksum signatures?
Thanks, Kev
Chris Toseland
