I have a question on my 9010a I run fide i found some scripts for omega race on john flippers site that are a .s I know a dot h file can be run on rksic.exe What do you use a .s file on Do you have to convert it ? How Can I use it in fide ? When I generate a script on fide not all the test for ram run Only test 2 and 4 work (this is on a working board) I did cut the watchdog reset and tied the cpu side high I wish someone would do a post on how to generate a script on fide If you do it right off his site you get errors I always need to change the names of the roms to get it to run And not all the test work So I try to test a working board first Thanks tony _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Tony htbs
