How to enable EDITOR on 9100s?
I am obviously overlooking something obvious, but how does one enable the EDITOR on a 9100 that is running 6.1 and has the video card installed? I tried using the service 6.0, but EDITOR does not appear to be an option. What is particularly annoying is I had editor on a 9100 which did not have the video card and when I pressed EDIT it would lock up. I then did some software tweak that removed EDITOR as an option, but I can't find that option again! I feel like an idiot, but I'm hoping someone will take pity no me and say the magic words (RTFM I suspect!) to fix this idiotic problem. Thanks! John :-#(# -- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
John Robertson writes:
I’ve been tripped up by this before as well. It’s buried in the menu system of the OS, you don’t need the service disk. Press the SETUP MENU key, then right arrow, SOFT KEYS to see more labels, F5 to select ON BOOT. You can enable or disable EDITOR and the IEEE-488 interface from that menu. Then back to the root and SAVE SYSTEM SETTINGS IN USERDISK, and reset. -- Ian
-- Ian
Thanks Ian, that was exactly correct. Editor 6.1 is now installed during the boot. When I have time I will build a menu tree for 6.1, I should have some free around 2040... John :-#)# -- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist
