I have a Data I/O 29B EPROM programmer with a Unipak 2B and need to get hold of an adaptor for it, specifically adaptor no: 351B068 Does anyone either have one of these or know what it consists of please? Does it perhaps just re-route a few pins, or is there more to it than that? Thanks, Phil _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist
You mean a 351B-086 ? I've been thinking about running some of these. The only problem would be the plastic housing. All that is inside it is an 27HC299, a handful of diodes, couple caps, 1 resistor and a 28 pin zif socket. Any interest in these without the plastic housing? - Mike -
-----Original Message----- From: techtoolslist-bounces@flippers.com [mailto:techtoolslist-bounces@flippers.com] On Behalf Of Phil Morris Sent: Monday, May 30, 2005 6:39 AM To: techtoolslist@flippers.com Subject: [Techtoolslist] Unipak 2B adaptor query
Thanks, Phil
I think that's a separate adaptor, in the Unipak2B.txt file that I have it has the entry as: 351B068 that's for the PROM I need to program, namely the 82S115 BUT there's also a 351B086 listed for other chips.
How much each? I'm only, at this moment, after the 068 version. Phil _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist
I really depends on what it costs to run them. I didn't realize there was a 068 also. Could probably do bare boards pretty inexpensively. I've seen so many Unipak 2Bs with no card, that I was considering making something so they'd at least be useful. - Mike -
-----Original Message----- From: techtoolslist-bounces@flippers.com [mailto:techtoolslist-bounces@flippers.com] On Behalf Of Phil Morris Sent: Monday, May 30, 2005 4:04 PM To: Technical Tools Mail List Subject: RE: [Techtoolslist] Unipak 2B adaptor query
351B068
Phil
"Untitled 1" (missing attachment) _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist
I'd be up for one also - I have a spare Unipak 2B with that space empty. Best Regards, Bill -----Original Message----- From: techtoolslist-bounces@flippers.com [mailto:techtoolslist-bounces@flippers.com]On Behalf Of Martin White Sent: Monday, May 30, 2005 6:09 PM To: Technical Tools Mail List Subject: Re: [Techtoolslist] Unipak 2B adaptor query I'm not sure which adapter you're referring to, but if it's the one that goes in the middle at the bottom in place of the one you normally use for 27256 / 27512. which then allows you to go much higher than that (27C010 for instance i seem to remember), then i'd be interested since i've been after one of those since i bought my unit and i've never seen one available to the UK yet... Of course if it's not that one then ignore me :) Martin. On Monday 30 May 2005 23:21, Mike wrote:
- Mike -
351B068
problem would
27HC299, a handful
Phil
A bare board sounds fine as I can't imagine that would cost more than a few dollars. Not sure how much of a market there'd be for them though. Phil _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist
Bill Karkula -
Mike -
Phil Morris
