Re: RE: RE: Fluke 9010a question
Nor are many systems as easy to disable as Atari. On Pac Man Midway instructs you cut a trace or a pin to do it manually. Gorf is a similar example of what James B is refering to, it has a latch to select a section of RAM. That latch is also tied to the /RESET so you can test everything else fine by ignoring the /Resetting of the UUT but not that section of RAM. Kev <james@quarterarcade.com> wrote.
You can't always disable the reset or watchdog in software. You can ignore the reset line, but sometimes the watchdog can mess up your standard tests. (I *think* Centipede is an example of this... Been a while since I tried it.) I used to just ignore the status line via software, but nowadays I always ground the watchdog disable.
JB
--James Bright www.QuarterArcade.com Restored Arcade Games for your Home
If you ever want to (un)subscribe yourself with TTL, you can send mail to: <Majordomo@flippers.com> with the following command in the body of your email message: (un)subscribe techtoolslist or from another email account, besides xxx@yyy.com: (un)subscribe techtoolslist xxx@yyy.com
Williams is a PITA too ... You have to make a cut. When I was doing those, I was trying to ignore reset in software. It worked mostly... but I disliked working on them so much that I didn't spend too much time on them. JB --James Bright www.QuarterArcade.com Restored Arcade Games for your Home
-----Original Message----- From: owner-techtoolslist@flippers.com [mailto:owner- techtoolslist@flippers.com] On Behalf Of kklopp Sent: Saturday, January 24, 2004 5:04 PM To: techtoolslist@flippers.com Subject: Re: RE: RE: Fluke 9010a question
James Bright -
kklopp
