Re: [Techtoolslist] Techtoolslist Digest, Vol 119, Issue 1
Thanks John - Was a mixture of two issues; I wondered about using the LS's as well - didn't key in that the C's were CMOS right away but had some HC245's on order by the time you replied. It also appears that some of the "tested good" 74C245's were marginal. After replacing all of them with the 74HC245's, it's working great! Otherwise, had a link to the FTP site - but had to back up a few directories to find the ROM files, so I'm good there as well. Regards, Brent On Thu, Oct 2, 2014 at 12:48 AM, <techtoolslist-request@flippers.com> wrote:
Send Techtoolslist mailing list submissions to techtoolslist@flippers.com
To subscribe or unsubscribe via the World Wide Web, visit https://pairlist7.pair.net/mailman/listinfo/techtoolslist or, via email, send a message with subject or body 'help' to techtoolslist-request@flippers.com
You can reach the person managing the list at techtoolslist-owner@flippers.com
When replying, please edit your Subject line so it is more specific than "Re: Contents of Techtoolslist digest..."
Today's Topics:
1. Re: Z80 Pod - weak signal strength? (John Robertson)
Message: 1 Date: Tue, 30 Sep 2014 22:59:36 -0700 From: John Robertson <jrr@flippers.com> To: Technical Tools Mail List <techtoolslist@flippers.com> Subject: Re: [Techtoolslist] Z80 Pod - weak signal strength? Message-ID: <542B9848.5040605@flippers.com> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
On 09/29/2014, 6:40 PM, Sprout wrote:
Relatively new owner, and learning my way around the hardware.. Picked up a Z80 pod as part of a larger bundle purchase that was flaky. Eventually got it working, and in the process replaced a few 74C245's on the secondary PCB with 74LS245's. Consistently passing self test now.
74Cxx(x) devices handle noise better than 74LSxx(x) as I understand it. Best to hunt the 74C245s down. Voltage swings are also a bit better allowing for a better noise immunity over the length of the cable.
Initially, when it was somewhat flaky (and before I appear to have blown the '245's by troubleshooting with the pod removed from it's shell - gotta be very careful the two boards don't come apart while moving it around :P Initial issue was the two boards were poorly seated), I had a couple of good game boards where it allowed me to consistently run UUT with no issues. Since then, I'm noticing certain boards will run perfectly with the pod (ie Galaxian), and others (Jr. PacMan, Sega Frogger, Ms. Pac modified to run Crush Roller) just constantly watch-dog. My guess is that I have poor signal strength between the pod and the PCB's, but wanted to see if anybody found this as a common issue, and whether there are any components in the pod that may be worth looking at/replacing to address this? The Ms. Pac board has the small satellite board, and I noticed if I bypass it and go directly to the main PCB socket, the board is a bit more active, which makes me feel I'm on the right track. Jr. Pac doesn't use that however, and refuses to budge.
I've verified all the '245's and '374's check out good as per the IC test functions on my EPROM programmer, and again - passes self-test consistently. When on the Galaxian PCB, I could read ROM without issue, pass all RAM tests without issue - seems to work perfectly. Can't do anything on the others as it's complaining about active lines constantly, which are toggling because the boards seem to be watch-dogging as noted. If I disable active line monitoring, bus tests pass.
The ROM and RAM tests are run at the Pod's speed, not the UUT's (Unit Under Test) so they will often pass even if the Pod won't boot the board. Only if you have the Z80QT can you run RAM/ROM tests directly under the UUT's CPU at system speed.
I find one has to disable the watchdog to get these boards to boot from the pod...
I also built a new cable (slightly longer than the original) with no change in behavior. This one uses the standard, flat ribbon cable. Also dropped in a Z80B - no change; these boards are all running at 3.072Mhz anyway, which shouldn't be an issue...
The cable for each family of pod is a bit special - you have to have the correct one for yours. See notes at the bottom of my Fluke page:
http://flippers.com/fluke.html
I haven't taken a cable apart but I suspect there may be some funky bits in that rather fat header on some of them. Anyone with access to X-Ray equipment care to take a look?
Thoughts/suggestions? On a side note - what's the most current version on the ROM? Mine shows part# 536581, version 1.0. I found the Z80QT pod ROM and a few others online, but not this one. Plan to dump it regardless, but would like to upgrade if there's a newer version floating about.
... Thanks,
Brent
The ROM code has been up on the TTL FTP site for over a decade...lots of useful info there!
FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment
John :-#)# -- How to subscribe or unsubscribe from TTL http://seven.pairlist.net/mailman/listinfo/techtoolslist
Subject: Digest Footer
_______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist
End of Techtoolslist Digest, Vol 119, Issue 1 *********************************************
_______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com https://pairlist7.pair.net/mailman/listinfo/techtoolslist FTP site is: ftp://ttl.arcadetech.org/TTL/Test_Equipment Archive site: http://seven.pairlist.net/pipermail/techtoolslist/
Sprout
