Data I/O 29A Unipak Issues,(Promlink)
After a year of messing around with this thing off and on I finally got it working. I had to revert to Promlink version 2.4 and Windows 98 to get it running. Seems the later versions don't have the Unipak option. They only have Unipak 2B which is different. I also made a custom cable for it. So others wont have to go through the pain I did, here's the pin connections for making a cable: DB9 (PC) DB25 (29A) 2 2 3 3 8 4 7 5 5 7 I was able to use the default port settings to get things to communicate. Mark Hooks ----- Original Message ----- From: <techtoolslist-request@flippers.com> To: <techtoolslist@flippers.com> Sent: Saturday, September 16, 2006 12:00 PM Subject: Techtoolslist Digest, Vol 24, Issue 4
Send Techtoolslist mailing list submissions to techtoolslist@flippers.com
To subscribe or unsubscribe via the World Wide Web, visit http://seven.pairlist.net/mailman/listinfo/techtoolslist or, via email, send a message with subject or body 'help' to techtoolslist-request@flippers.com
You can reach the person managing the list at techtoolslist-owner@flippers.com
When replying, please edit your Subject line so it is more specific than "Re: Contents of Techtoolslist digest..."
Today's Topics:
1. Re: Data I/O 29A with Unipak Questions About Promlink (Mike Coates)
Message: 1 Date: Fri, 15 Sep 2006 19:06:24 +0100 From: Mike Coates <mike@the-coates.com> Subject: Re: [Techtoolslist] Data I/O 29A with Unipak Questions About Promlink To: Technical Tools Mail List <techtoolslist@flippers.com> Message-ID: <450AEBA0.7010903@the-coates.com> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
have you selected the right programmer type from the menu - it must match the plug in pack as well as the 29A bit.
for my 29A, I told it that it was a 29B anyway
Mark Hooks wrote:
I think I finally have my interface cable working between my PC and my 29A unit. I am using Promlink 6.10 to interface between my PC and the 29A. However, when I try to set the device I cant. I'm trying to read a 2708 and none of the menu options show it, even though the 29A device list says it should be there. For that matter nothing but PROM part numbers seem to be showing up. How do I fix this? Do I have an outdated data file in my promlink directory?
End of Techtoolslist Digest, Vol 24, Issue 4 ********************************************
Hi Mark ! I'm facing the same problem for years... Where can I find this Promlink copy ? Thank you very much ! JL -----Mensagem original----- De: techtoolslist-bounces@flippers.com [mailto:techtoolslist-bounces@flippers.com] Em nome de Mark Hooks Enviada em: sábado, 16 de setembro de 2006 22:55 Para: techtoolslist@flippers.com Assunto: [Techtoolslist] Data I/O 29A Unipak Issues,(Promlink) After a year of messing around with this thing off and on I finally got it working. I had to revert to Promlink version 2.4 and Windows 98 to get it running. Seems the later versions don't have the Unipak option. They only have Unipak 2B which is different. I also made a custom cable for it. So others wont have to go through the pain I did, here's the pin connections for making a cable: DB9 (PC) DB25 (29A) 2 2 3 3 8 4 7 5 5 7 I was able to use the default port settings to get things to communicate. Mark Hooks ----- Original Message ----- From: <techtoolslist-request@flippers.com> To: <techtoolslist@flippers.com> Sent: Saturday, September 16, 2006 12:00 PM Subject: Techtoolslist Digest, Vol 24, Issue 4
Today's Topics:
_______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist
At 12:00 AM -0300 10/9/06, Jose Luiz Martins wrote:
Hi Mark !
JL
It might be one of the old "PL" programs on ftp.flippers.com/TTL/TestEquipment/Data-IO/Promlink John :-#)#
for making a cable:
Today's Topics:
-- John's Jukes Ltd. 2343 Main St., Vancouver, BC, Canada V5T 3C9 Call (604)872-5757 or Fax 872-2010 (Pinballs, Jukes, VideoGames) www.flippers.com "Old pinballers never die, they just flip out" _______________________________________________ Techtoolslist mailing list Techtoolslist@flippers.com http://seven.pairlist.net/mailman/listinfo/techtoolslist
Jose Luiz Martins -
Mark Hooks
